Question about Kenmore 55683 Stainless Steel Side by Side Refrigerator
Scratched stainless steel
I scratched the stainless steel on the front. How do I repair it?
    New Friend:
  • 161 Answers
Hi Try www,finishing.com/4000-4199/4148.html I do not know if this will be helpfull, but give it a go
Posted on Nov 02, 2008
Can a dent at the front of a steel oven be fixed?
probably not perfectly, but you can order a new panel
Dec 24, 2014 | Stainless Refrigerators
Fisher paykel scratches on front of stainless steel. How do I repair? I see there are repair kits but have to be sure there is no protective coating on the stainless. Is there and if so then what do I do...
If they are shallow scratches you could try using Lemon Pledge... that covered up really small scratches on mine and also stops fingerprints on the stainless steel.
Sep 03, 2013 | Dishwashers
My new lg refrigerator is scratched on the stainless steel can i get it repaired
You can but it will always short some sort of problem there. Hope this helps. Wally.
Oct 09, 2011 | Refrigerators
How to remove scratches from stainless steel appliances
Try this at your own risk. Step 1 Consider using a product made for stainless steel2_bing.gif such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
  • Step 2 Or, try spraying an all-purpose cleaner (such as Formula 4092_bing.gif) on the scratches.
  • Step 3 Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
  • Step 4 Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
  • Step 5 Rinse the surface and wipe dry.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Tips & Warnings
    • Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
    • A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
    • Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
    • To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
    • Avoid using abrasive
    Please rate 4 thumbs for the free answer
    Mar 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Stainless Steel Sink Question
    s with most things, your stainless steel sink WILL scratch with use. However, over time as the sink ages, scratches will become less apparent and in fact blend into the surface. Minor scratches on the inside surfaces of the bowl may be blended into the sink by lightly rubbing a Scotchbrite pad in the direction of the finish grain. Be sure to rinse thoroughly with water and towel dry after this procedure, removing any particles left over from the Scotchbrite as you rinse.
    Aug 27, 2008 | Advance Tabco Stainless 3 Compartment...
    Scratches on stainles steel door
    IF IT IS BRUSHED STAINLESS, AND THE SCRATCHES ARE REALLY BAD, YOU COULD TRY SOME STEEL WOOL TO SOFTEN THE SCRATCHES, BUT IT WILL BE A TRADE OFF OF MINIMIZING THE SCRATCHES AND CAUSING A SMEARED LOOK TO THE BRUSHED STAINLESS PATTERN.
    Apr 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
    SCRATCHED STAINLESS STEEL SINK
    Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
    Feb 08, 2008 | Kitchen Ranges
    Repair scratches on black door front
    Mr....other than repainting, the only suggestion I have is one of those scratch repair kits that they sell at Pep Boys. The finish materials...paints...not stainless...are about the same as used on cars. Use a soft lambswool bonnet buffer and go slow.
    If it is stainless...use 00 steel wool in a one directional sweep with a little bit of light oil.
    good luck, sir.
    Dec 03, 2007 | Samsung RS2556 Side by Side Refrigerator
    Stainless steel refrigerator with a bad scratch
    Check out this site and see if it helps. Usually stainless has to be buffed out. http://www.stretcher.com/stories/01/010723a.cfm
    Nov 06, 2007 | Refrigerators
    Kenmore 55683 Stainless Steel Side by Side Refrigerator Logo
    281 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De GO PATS
    Jim Goldsmith
    Jim Goldsmith
    Arnel
    Arnel
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
