Question about Motorola Mobility RAZR V3i Cellular Phone
Can Not Make Outbound Calls
I am able to receive incoming phone calls, but can not make outbound calls.
I want default call barring password for v3i
Posted on May 02, 2009
    Brigadier General:
  • 7,752 Answers
You need to check the phone settings to se if you have the call barring feature set, if it is then remove it
Posted on Dec 28, 2008
2 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: Outbound calling problem
master reset the phone or check your call barring feature and deactivate it.
APN for cleartalk flashed phone
Please contact your service provider, they will be able to help you out when it comes to service related concerns.
Jun 18, 2016 | Samsung Galaxy J1 J100M Unlocked GSM 4G...
I have 7 incoming lines, I can receive calls on all seven, but I am not able to make outbound calls from any of those lines. I have 6 extensions, out of those six extensions only one is able to make and...
Do you have actual appearance of each line, or just a placement button for calls received, a Call Arrival key, or car key. You can't grab a car key to make a call, the outgoing calls just land on them after you dial 9 or whatever the code is. Anyway, that would have to be changed in system programming, an actual tech would have to look at that. Or the phones are restricted and need a code entered to bypass the restriction. I have no idea how those codes might be set up.
Oct 09, 2013 | NEC Electra Professional ETW-16DC-2
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Mar 16, 2011 | Mitel PRI Card T1 E1 (9109615001)
Does this system have ability to block phone numbers?
Outbound yes, incoming no. In program 404, there are 8 lists of 10 numbers that let you set up restrictions and assign them to extensions.
I block my incoming calls by using my VoIP provider's call block feature.
Carl
Feb 07, 2011 | Lucent 18D Corded Phone
How can i get dailled numbers list
Sorry, your phone can keep a record of up to 100 incoming calls through its caller ID function, but on the outbound it only saves one - the last number dialed - for redial purposes.
Jan 06, 2010 | Uniden Cordless Phone
Can make outbound call on Blackberry Bold. Bought 2nd hand unlocked unit from the US. Can receive calls but everytime I try to make outbound calls it says: "Call failed due to SIM Toolkit control error....
This error is due to having an old SIM card.
Please talk to your carrier to get the latest SIM card.
You most likely have received an old SIM card batch.
Hope it helped.
Nov 23, 2009 | RIM BlackBerry Bold Smartphone
Nov 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
142 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
