Question about Kenmore 24032\24036 Top Load Washer
Kenmore Mod 110 keep spinning
The tub or barrel is constantly in motion - like a medium rate spin. The agitator works fine, but with the constant spin of the barrel during the wash cycle, clothes are being twisted and tangled , (actually ripped & torn) under the agitator, (around i'ts base). It works fine during the spin cycle, when it's supposed to constantly turn, and does so with an appropriate increase in the speed of the spin. We removed the agitator to check on it, (it's fine) but we did find two holes on opposite sides of the staff, and couldn't figure out if something there had been lost or broken. All in all, it works fine providing you manually hold the barrel in one place during the wash (agitating),and rinse cycles.
Thanks
  • unclejer Nov 02, 2008
    Thank you for your help.
  • unclejer Nov 03, 2008
    How do i check to see if that it or not.
    Sergeant:
    Champion:
  • 324 Answers
The holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Posted on Nov 02, 2008
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
Kenmore 90 series mod 110. 478621 leaking from above the transmission . How to check drum seal. Thanks
Remove the agitator, you need a spanner wrench to remove the nut holding the spin tub down, then it will lift out. You will need a new tub donut seal that fits into the outer washtub, check for corrosion on the support tube, if it is corroded and not smooth, it will likely leak with the new seal.
Apr 23, 2016 | Kenmore Washing Machines
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
Kenmore Elite 110 does not spin/agitate/drain
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Kenmore Elite 20972
KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
136 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
