Question about InFocus LP350 Multimedia Projector
Projector not working
my projector will not do anything, when turned on fan won't even run. I have checked for power, it's good, however I have no lights, no fan, nothing. I am at a loss please help.
Thanks
K.Hill
Have you tried the internal fuse? without a proper fuse in the panel you will get no power i.e. lights and such to the device. Simple but the first place to check.
Posted on Nov 03, 2008
All the lights flash the fan runs continuously and it has trouble powering up and down
NHSA275W
1,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 18, 2013 | Christie LX505 OEM Projector Lamp
Sony VPL FX50 Won't power up. Bulb appears to be fine.
an electrical issue (power supply area) is correct. check manufacturer for part replacement info would be the best move.
Jan 03, 2008 | Sony VPL FX50 Multimedia Projector
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
panel, Lens, DMD chip, color wheel,
competitive price.
any questions, feel free to contact me
have a nice day!
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
Epson projector bulb won't turn on when rpalced
Apr 18, 2012 | Epson ELPLP09 Projector Lamp for PowerLite...
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
My church has an EIKI LC-X986 projector that turns on for about 2 seconds then shuts down. The lamp is brand new and the filters are clean. I know the signal is working as I can see it for those 2...
Have a close look at the fan and check if there is a make and model number on it.
If you cant see anything, unscrew the fan and check on the hidden sides.
see what voltage it is. ie 12v dc or 24v dc
Ring the EIKI agent and ask them how much for a replacement rear fan, the EIKI part number, and also if they can supply the manufacturer of it and their part number.
Check that the fan connector is OK, and the socket where it plugs in.
Check that the fan turns freely.
report back what you find
Mar 24, 2011 | Eiki LC-X986 Projector
Invalid lamp ballast id on 16k Christie This happens when the projector is powered up and the on button pushed. The lamp will strike after many tries ie dropping power and re powering once running no...
Have a good day!
wheel,
Sep 23, 2009 | Christie Office Equipment & Supplies
Whats wrong with my projector?
Hi Trezza
No this is absolutely NOT a lamp issue.
Take of the top cover and switch on the machine - check that all the fans are working.
If they are all running , this might be a faulty Mainboard.
If you can't spot anything wrong yourself , rather take it to a repairer for a proper inspection.
Good luck and thanks for using Fixya !
Apr 27, 2008 | Office Equipment & Supplies
Dell 1100mp data projector
check fan filters.
sounds like you have an airflow problem.
open up and clean out dust.
or fan failure.
check fans are spinning when pj is switched on.
Feb 26, 2008 | Dell 1100MP DLP Projector Multimedia...
174 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
