Question about Candy CN146 Front Load Washer
Candy Activa C2 510
Hi Guys,
I have problems with my CANDY. Every time I start it - it reaches a certain point when it stops (in the middle of washing) and 2 leds from the indicators start blinking (led R++ and the led for 90 minutes remaining). After I start the program again - it completes OK. How can I solve that or I should bring the machine to technician?
Thanks
4 Suggested Answers
SOURCE: Candy Activa Smart 1300 AA
Many thanks had already done this and all is working fine now fingers crossed!
Posted on May 31, 2008
  • 6277 Answers
SOURCE: My Candy washing machine stops
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 12, 2011
KevinWhite
  • 1902 Answers
SOURCE: Candy Grand 1600 AAA class
Hello & Welcome to FixYa
You can start with cleaning the drain filter pump assembly located inside the front bottom panel of the washer. After it's cleaned and the problem is back then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jun 19, 2011
I have a Candy CM126 washer. It will not go into the spin cycle. I have cleaned the filter and checked if the pump is ok. They are fine. However when the machine stops the Activa rinse and 90' lights flash...
It could be the NTC ? two small wires between the heat main wiring. Or Possible the heater is leaking to earth. You would need a meter to test , NTC should be about 18kohm
Sep 15, 2017 | Candy Washing Machines
2013 Honda Activa will not idle when warm
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda Activa 2013 Engine Stalling
Honda Activa Engine idling stalling issue caused by faulty ring fitment...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jun 28, 2014 | 2011 Honda Activa
After candy crush update the game dont work anymore. what now?
Sounds like you reached the point they will let you play until they stop you unless you pay for something.
Apr 14, 2014 | Tablets & eReaders
Cheats and cheat codes
Candy Crush Saga Level 213 help, tips and tricks In Candy Crush Saga level 213 we need to clear all of the Jelly blocks and score at least 130,000 points within 40 moves to defeat this level.
How to Beat Candy Crush Saga Level 213 (cheats ?) In level 213 we can see that we have double jellies everywhere, so we will need to do some serious clearing of candies in the board.
If we can make the wrapped candy + wrapped candy combo just outside the meringues perimeter, this will help us out a lot, but there's still a lot to be done to clear this game.
Once the chocolate fountains come into play we will face even more distractions and make the game even more difficult.
We should keep track of which jellies has been cleared so we don't need to worry about those candy squares afterwards if the chocolates covers it up.
There will be 70 pieces of jellies we need to get, so we should make the best candy combos that can crush through the meringues and get to the jellies underneath.
The bottom pieces are of course the hardest ones to clear here, so any vertical candies we make will be extra helpful in passing through here.
Stars
1 star: 130,000 points
2 stars: 250,000 points
3 stars: 300,000 points
Candy Crush Saga Level 213 Help Tips Tricks and Cheats
Feb 25, 2014 | Microsoft Video Game Consoles & Games
2011 Honda Activa poor acceleration
Hi, Negiakash007 and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Pinholes or torn diaphragm.
6. Accelerator pump leaking or no output.
7. Plugged bowl vent or overflow.
8. Fuel level in bowl too low.
9. Restricted fuel supply passages.
10. Plugged jets or passages.
11. Worn or damaged needle or needle jet.
12. The enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2003 Honda Activa Valves gone bad Team BHP
Honda Activa throttle problem
May 16, 2012 | 2011 Honda Activa
Stops pumping in middle of program
I know it is a bit late, but maybe it would help the others.
This E3 error means, that the water temperature did not reach desired level (for example 60C if you are using 60C program) in a given time.
The dishwasher starts the heater and waits for example 10 minutes for the water to reach the temp.
The heater is located on the left side of the dishwasher - it heats
water flowing from the bottom bowl to the sprinkler on the top.
There can be few reasons:
- the heating device is dead - easy to check - if the water is hot when E3 appears, then this is not the case
- the water duct from the bottom bowl to the top sprinkler is messy, and needs cleaning (there are some rubber pipes of quite small diameter)
- the temperature sensor (thermistor) is dead / not responding fast enough. It is mounted to the bottom bowl and can be reached from the front cover, under the doors.
Hope it would help to somebody.
I have already had this and few other problems. All of them have about 5-6 reasons to appear, and I think I know all of them for now :-)
For me, knowing what to expect and how to fix each E-something, this dishwasher is perfect and will last forever :-)
Regards,
Piotr
Jan 19, 2009 | Candy Dishwashers
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 25, 2008 | Candy AQ130 Front Load Washer
Stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Dec 16, 2007 | Candy CN146 Front Load Washer
Candy cic60 01 condenser dryer
check the vent line it may be cloged or bent if this is good then possibly the hi temp sensor may be bad ?
Nov 15, 2007 | Candy CDC266 Dryer
Candy CN146 Front Load Washer Logo
63 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
