Question about LG 42PX3DCV 42 in. Plasma EDTV
LG 42PX3DCV 42 in.
I have red, blue and green pixels in all dark areas. tv worked great at store, when i hooked it up at home bad picture. tried dvd player, video games and different connections still same result. this is a plazma tv, it stayed upright the whole time.
jim
  • 505 Answers
Pixel misfiring (diffusion errors) are caused when the tv is not firing and erasing the pixels correctly. It can be caused by a number of things, usually a voltage or waveform is off somewhere. If you just bought the tv, return it and get another. If you are out of warrany, you can remove the back panel and run the tv to check the voltages. Don't touch the heatsinks! they're electrically hot and will zap you.. the voltages are labeled on the back of the plasma panel with a sticker. first check Vs and Va. sometimes you can check -Vy, Vset, Vscan and others if labeled on the board. If you have to adjust waveforms you need a very $$ o-scope and should get qualified technician to adjust. If a board is bad, its likely your power supply or Y-sustain pcb, and less likely your Z-sustain or contol (logic) board.
Posted on Dec 07, 2008
Directv can't connect my tv to he, what can I do, they say I need a green plug in in the back,with the red, yellow, white
What I believe they are trying to tell you is you need to hook up into a component input . It is a video input only and it has three jacks usually coloured red green and blue. Match up the colours with the receiver and you will get an HD picture. They way you currently have it hooked up is a composite connection with only the yellow being for picture. This cannot get you an HD picture. The red and white is for the sound. I don't know what you mean by he though.
Sep 24, 2015 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
HALF PICTURE ON LG PLASMA MODEL 42V7
first check all of your ribbon cables. then check the lvds cable. if this dont fix then you will have to get a service manual and run the panel by itself to determin wich circuit your problem is in. any questions feel fre to contact me....
Oct 17, 2007 | LG 42PX3DCV 42 in. Plasma EDTV
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
I have a LG plasma 42PC1D (4 years old). For the
I had the same problem a few months after buying the TV, called LG and they sent a tech to replace two boards in the tv. No further problems since.
Dec 21, 2009 | LG 42PC3D 42 in. Plasma Television
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Red/pink shades in dark areas happens only 6ins down from top
Sounds like you have a cap that leaky or a ic thats getting hot,
if you want to try and fix it yourself get a can of freeze it
http://www.chemtronics.com/products/product.asp?id=78
and when the problem appears spray the can on each (ic or cap) part till the problem goes away.
Dec 03, 2007 | LG DU-42PY10 42 in. Plasma HDTV
LG 42PX3DCV 42 in. Plasma EDTV Logo
406 people viewed this question
Computer Repairing
Computer Repairing
