Question about Canon NP 7130 Black and White Copier
Having trouble loading toner cartridge can't turn cartridge
I'm don't have manual. I can put toner Cartridge into unit can't tun cartridge to lock and allow toner slots to line up. Is there a locking mecanizim I am over looking.
  • 318 Answers
Yes,there is a arm that have to slide left to close the upper body.If the toner is in place you can close it slowly,with your finger you can guide that arm in the correct position.It will work untill you can get a technician to fix that for you.The technician have to strip the controll panel and boad to get to that locking device.
Posted on Nov 03, 2008
Where is the drum on the MFC-8860DN and how do I remove it?
The drum is part of the laser toner cartridge
Open the front door
Press the square button in the center of the paper receiving are, it is marked with a small triangle
Press and pull, it will open a door showing the toner cartridge
Pull out the toner cartridge
The top part is black and the bottom assembly is grey
There is a blue little latch in the right side of the cartridge
Press the latch and the toner cartridge will be release
Remove the toner cartridge.
You need to replace the grey bottom assembly with a new one
A compatible assembly, which will have a new drum, will cost around
$30 at amazon an oem around $70
Reassembly and reinstall in reverse of the disassembly
I hope this was helpful
Mar 17, 2015 | Brother MFC-8860DN Printer
DCP 7060D replace cartridge
Sir/Madam
I suggest You Go To http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000065/faq000065_056.html?reg=eu&c=eu_ot&lang=en&prod=dcp7060d_all
Above URL Link To Fix Your Brother Printer Issue Or Brother Printer Problem To Perform Below Brother Printer Step:
Title:
REPLACE TONER (video instructions available)
Description:
The message REPLACE TONER indicates the toner cartridge needs to be replaced with a new one. Please follow the steps below to replace the toner cartridge.
NOTE: Videos and illustrations shown below are from a representative product and may differ from your Brother machine.
HINT:
The Brother machine has separate consumables: the toner cartridge and the drum unit. Verify you replace only the toner cartridge, and not the drum unit. Click here to see the difference between the toner cartridge and the drum unit. Also you can confirm the order number (Order No.) of the toner cartridge on the Consumables & Options page. Click here to go to the Consumables & Options page.
Make sure that the machine is turned on. Open the front cover and leave the machine turned on for 10 minutes to cool down.
* This movie is being streamed from YouTube. (Opening new window.)
Caution
You must ensure the machine is turned on when you replace the toner cartridge so that the machine recognizes the toner has changed.
After you have just used the machine, some internal parts of the machine will be extremely hot. Wait for the machine to cool down before you touch the internal parts of the machine.
Hold your Brother machine with one hand, and take out the drum unit and toner cartridge assembly by pulling on the handle in the middle of the drum unit and toner cartridge assembly. We recommend that you place the drum unit and/or the toner cartridge on a clean, flat, level, stable surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
DO NOT use cleaning materials that contain ammonia, alcohol, any type of spray, or any type of flammable substance to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
DO NOT use any type of spray.
Push down the green lock lever and take the toner cartridge out of the drum unit.
Caution
DO NOT put a toner cartridge into a fire. It could explode, resulting in injuries.
Be careful not to inhale toner.
Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wipe or wash it off with cold water.
To avoid print quality problems, DO NOT touch the shaded parts shown in the illustration.
Be sure to seal up the toner cartridge tightly in a suitable bag so that toner powder does not spill out of the cartridge.
Go to Above Mention Official Brother Printer Url Link for instructions on how to return your used consumable items to the Brother collection program. If you choose not to return your used consumable, please discard the used consumable according to local regulations, keeping it separate from domestic waste. If you have questions, call your local waste disposal office.
Unpack the new toner cartridge. Hold the cartridge level with both hands and gently shake it from side to side several times to spread the toner evenly inside the cartridge. Pull off the protective cover.
Caution
Wait to unpack the new toner cartridge until immediately before you put it in the machine. If a toner cartridge is left unpacked for a long time, the toner life will be shortened.
Put the toner cartridge in the drum unit immediately after you have removed the protective cover.
To prevent any degradation to the print quality, DO NOT touch the shaded parts shown in the illustrations.
DO NOT touch the toner surface.
Brother strongly recommends that you DO NOT refill the toner cartridge provided with your machine. We also strongly recommend that you continue to use only Genuine Brother Brand replacement toner cartridges. Use or attempted use of potentially incompatible toner and/or cartridges in the Brother machine may cause damage to the machine and/or may result in unsatisfactory print quality. Our warranty coverage does not apply to any problem that is caused by the use of unauthorized third-party toner and/or cartridges. To protect your investment and obtain premium performance from the Brother machine, we strongly recommend the use of Genuine Brother Supplies.
Put the new toner cartridge firmly into the drum unit until you hear it lock into place. Make sure that you put in the toner cartridge properly or it may separate from the drum unit. If you put it in properly, the green lock lever will lift automatically.
Clean the primary corona wire inside the drum unit by gently sliding the green tab from left to right and right to left several times. Be sure to return the green tab to the home position. If you do not, printed pages may have a vertical stripe.
Put the drum unit and toner cartridge assembly back into the machine. Close the front cover.
Note
After replacing the toner cartridge, DO NOT turn off the machine's power switch or open the front cover until the LCD clears the Please Wait message and returns to Ready mode.
If the error message still continues to appear, refer to
Or
If You Still Having Brother Printer Technical Problem then Follow Us For On :
Brother Printer Support
Jan 23, 2014 | Brother Office Equipment & Supplies
HOW TO REPLACE THE OLD TONER CARTRIDGE WITH NEW ONE?
Here's the process:
1) Make sure that the printer is turned on. Open the front cover. 2) Take out the drum unit and toner cartridge assembly 3) Push down the green lock lever and take the toner cartridge out of the drum unit. 4) Be sure to seal up the toner cartridge tightly in a suitable bag so that toner powder does not spill out of the cartridge. 5) Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. 6) Pull off the protective cover. 7) Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. 8) Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. 9) Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
That's it. You may also want to download the user manual as it has photos along with the instructions above. You can obtain that at: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Hope this helps!!
Jun 20, 2011 | Brother HL 2140 Laser Printer
Don"t know to change the toner it was donated and
There are usually picture instructions on the Canon toner box. But here it goes - Gently shake the toner cartridge to break up the fine toner powder. Then open up the front door, the you should see a blue handle on the right side, rotate this in the counter clockwise direction. The Developer should move to the right and gently pull this out as far as it will go. Put the toner cartridge on top of the developer assembly and gently push down until it locks in. You will have to angle the rear facing end of the cartridge so that it slips into a slot. When the cartridge is lock the tab should break away. Before pulling this tab away from the copier lift up on the cartridge to guarantee that the cartridge is locked into place. You don't want to pull the tab until locked because you will have abig mess to clean up. The tab will open up the developer unit and the toner will drop inside. The you close up the slide and at the end of this procedure you may have to place a thumb on each side of the slide and fingers on the blue finger catches to fully close the developer unit. The cartridge should release and then remove the empty toner cartridge. Throw it away, return the developer to its normal position, close the front cover.
Jun 20, 2011 | Canon imageRUNNER 2200
I have a Brother HL-2142 Compact High quality mono laser printer and I am having trouble putting the new toner cartridge back in as it flashes error and the paper gets jammed. I dont know where the...
Open the front door and pull the whole toner and drum unit out of printer. The toner locking lever is usually on the left hand side as you see it and is usually blue in colour. It needs compressing and at the same time lift the front of the toner cartridge out of the drum unit. Your new cartridge will simply lock into place. When you install the complete unit and close the door, the new toner cartridge will reset your printers counter.
May 20, 2011 | Digital Products Brother HL-2040 Laser...
Error button is on saying paper jam, i got the paper out but it did not turn off the red error light. what do i do? i am so confused.
Sorry to hear you are having problems. Printers can be very frustrating at times. Below is a description of how to completely clear paper jams. Paper can get jammed in there pretty tightly and in very small places. Ensure you've followed all the steps to clear your paper jam and you should see your printer start working again. Refer to your user guide (or download via the link provided at the bottom) for illustrations.
  1. Open the front of the printer.
  2. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  3. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  4. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  5. Close the front cover.
    Note: Do not put the drum unit and toner cartridge assembly back in at this point.
  6. Pull the paper tray completely out of the printer.
  7. Pull the jammed paper down and out of the printer.
  8. Open the back cover (back output tray).
  9. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  10. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
    After you have just used the printer, some internal parts of the printer will be extremely hot. Wait for the printer to cool down before you touch the internal parts of the printer.
  11. Close the back cover (back output tray).
  12. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
    Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    To avoid print quality problems, DO NOT touch the roller part of the toner. Try to keep you hands, fingers and everything else away from there.
  13. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  14. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  15. Put the paper tray firmly back in the printer.
  16. Close the front cover.
  17. Make sure that the Error LED is now off.
Jan 23, 2011 | Brother HL-2170W Laser Printer
BROTHER-MFC7430 Toner life end
actually, you dont' really need to replace your drum, your drum actually is good for 5-6 years.
you just need to clean up the drum with duster and put that back into the machine.
when reset the drum, you just need to open the front cover and press Clear buttom then 1.
after that the whole thing will be reset and ready to go for it.
Dec 27, 2010 | Brother MFC-7340 All-In-One Laser Printer
I was unable to loace the Toner Cartridge. Could you please tell me where to open up and how to replace the tomer cartridge? Thank you. Regards, Lisa Li
Make sure that the printer is turned on. Open the front cover. Slowly but firmly pull the drum unit and toner cartridge assembly out of the machine. Push down the green lock lever and take the toner cartridge out of the drum unit. Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. Pull off the protective cover. Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
If you want even more detailed information, there is a how to guide with ilustrations on each step on the Brother website.
Dec 07, 2010 | Brother HL 2140 Laser Printer
How do i reset the brother dr350 drum
If you have already replaced the drum - only do steps 1, 2, 3, 7 and 8.
1. Make sure that the printer is turned on and the Drum LED is blinking. Open the front cover of the printer.
2. Press and hold the GO button for about 4 seconds until all the LEDs light up. Once all four LEDs are lit, release the GO button.
3. Pull out the drum unit and toner cartridge assembly.
4. Push down the blue lock lever and take the toner cartridge out of the drum unit.
5. Unpack new drum unit.
6. Put the toner cartrisge firmly into the new drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
7. Put the drum unit and toner cartridge assembly in the printer.
8. Close the front cover.
Jan 29, 2010 | Brother HL-2040 Laser Printer
How do I add toner to machine? Also, is this copier do color copies?
1 Open the front cover and pull out the
2 Hold down the lock lever on the left and
pull the toner cartridge out of the drum
unit.
3 Unpack the new toner cartridge. Place
the used toner cartridge into the
aluminum bag and discard it according
to local regulations.
4 Gently rock the toner cartridge from side
to side five or six times to distribute the
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place. If you
automatically.
7 Clean the primary corona wire inside the
drum unit by gently sliding the blue tab
from right to left several times. Return
the blue tab to the Home position (▼)
before reinstalling the drum unit and
8 Install the drum unit and toner cartridge
assembly in the MFC.
9 Close the front cover.
If you need illustration for this, click on the link below and turn to page 112
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 02, 2009 | Brother MFC-7820N All-In-One Laser Printer
Canon NP 7130 Black and White Copier Logo
70 people viewed this question
old marine
old marine
