Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My dishwasher is working ok except that there is a big pool of (not a small pool)water left at the bottom when cycle finshes. I have a feeling that my drain pump is not working because I dont hear it go off during the washing cycle and there is a complete silence in between the washing. I want to reconfirm if this is what the problem is however dishwasher is not over-flowing water is not flowing out of it and I am thinking that this is because of some built-in safety mechanism.
  • 5 more comments
  • squattie Dec 10, 2007
    water is leaking at the bottom left corner where there is a little tube.
  • Anonymous Jan 20, 2008
    My Frigidaire FDB510LC will not drain. The sink or disposal is not stopped up. I have looked down into where the water drains and there isnt any debris.
  • Anonymous Feb 01, 2008
    i have the exact same problem. My dishwasher has a olimpic pool at the bottom every time a cycle is done. I just bought this Dishwasher 6 months ago.
  • Anonymous Feb 13, 2008
    at the end of the cycle, there is water that does not drain, removed the bottom parts to see if the was any thing blocking it's drain path. there was a little foreign matter, removed and tried again. same results. sounds like motor in running. help
  • mustangpro1 Mar 29, 2008
    I HAVE THE SAME PROBLEM THEIR IS A POOL OF WATER LEFT IN BOTTOM OF DISHWASHER I PULLED OFF DRAIN HOSE AND CLEARED LINE OUT BUT I DONT HERE THE WATER DRAIN ANYMORE CAN ANY ONE HELP
  • Anonymous Aug 07, 2008
    water left in the bottom of dishwasher after it cycles
  • jhruston Nov 13, 2008
    I have the same problem with a Siemens Ecosense Dishwasher which we have had for a few months. Sometimes it pumps out completely at the end of the cycle, sometimes it doesn't.
I INSTALLED A NEW GARBAGE DISPOSER AND THEN FOUND THAT THE DISHWASHER WOULD NOT DRAIN. READ THAT THERE WAS A SEAL IN THE NOZZLE OF THE GARBAGE DISPOSER THAT HAS TO BE REMOVED IF IT IS ATTACHED TO A DISHWASHER. I DISCONNECTED THE HOSE,WITHOUT REMOVING THE GARBAGE DISPOSER, PLACED A SCREWDRIVER IN THE HOLE AND HIT IT WITH A HAMMER AND KNOCKED IT OUT. REPLACED THE HOSE AND TIGHTENED THE RING AROUND THE HOSE. TURNED THE DISWASHER TO DRAIN AND IT WORKED PERFECTLY. MY MISTAKE FOR NOT READING THE DIRECTIONS THOROUGHLY. ALL IS WORKING WELL; HOPE THE SAME FOR YOU.
Posted on Jun 21, 2010
I just fixed the problem with my dishwasher. I removed the drain hose from the disposal and used my shop vac. to suck food particles out of the hose. That was after I removed the screen/filter from inside the dishwasher and cleaned that. Works normal again.
Posted on Mar 29, 2008
    President:
  • 878 Answers
Wahmad, your safety device would be the float assy. First check your drain hose. If you have it going to a siphon break at the sink, these have a tendency to clog up. The drain pump is seperate from the wash motor. You can check to see if it's receiving voltage during the drain cycle with a meter. If you are showing voltage and no drain, there's your problem. Part number for the drain pump is 154407401. Catriver...post back.
Posted on Sep 26, 2006
SOURCE:
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
Water staying in machine after wash completed
Hello. Generally, the problem is debris in the drain pump or in the drain line which goes from the base of the machine up into the drain under the kitchen sink. Begin by removing the lower panel on the front of the dishwasher and disassembling the drain line there. Be prepared for about 3 cups of water. Then REmove the pump and visually examine it on the inside. If you don't find the debris there check the entire drain tube, and the connection area under the sink. J.
Jul 28, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Dec 15, 2008 | Whirlpool Dishwashers
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Jun 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
3,185 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
