Question about Refrigerators
Water inside refrigerator
Need to know where drain tube is so can attempt to clear
  • 59 Answers
The drain tube starts under the evaporator behind a panel in the freezer section. If you have a fairly new (within 10 years) model with the freezer on the top then the actual tube is hidden and can't be accessed. To clear this you'll need something with high pressure, like a steam cleaner, to blow the clog out. It you have a side by side model the tube can be accessed from behind through the service panel. The tubes aren't always clogged though sometimes they just freeze over. In these cases after clearing the ice twist one end of a regular (fully stripped) electrical wire around the heater above the drain hole then cut it with enough length to extend 2in down into the hole. Hope that helps!
Posted on Nov 02, 2008
Our kenmore top freezer is leaking (dripping water) inside the refrigerator section from around the dial area. Can fill up a small bowl in about 12 to 24 hours.
Most likely your defrost water drain is plugged. You will have to pull the panels off the freezer, to expose the evaporator. the defrost water drains by gravity thru a hole in the pan under the evaporator. Clear it of debris and or ice, check for any accumulated ice. reassemble. Remember to turn off power before attempting repair and be careful not to bend or puncture any refrigeration tubing
Jul 05, 2011 | Kenmore 64802 Top Freezer Refrigerator
There is a hole in the bottom rear of the freezer of my side by side full of water and the over flow is frozen all across the bottom and it leaks onto the floor
How To Clear the Drain Tube Before clearing the drain tube, unplug the refrigerator or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2011 | Refrigerators
Need to know easiest fix for clogged defrost drain tube
Wet dry shop vac. Remove the food and the service panel. Let her thaw out.
GE Bottom mount service manual
Feb 10, 2011 | GE Refrigerators
Ge top freezer model tbx211a leaking water on occasion inside fridge
Drain is clogged inside freezer.
Your model number is missing a few characters, but this model should have a black tube coming out of the back side of your refrigerator about 1/2 way from the floor that drains into a pan underneath near compressor. Check this first to see if it is clogged. Carefully pull it off where it enters the back wall (will need to pull out refrigerator to access this) try running a wire into tube to clear and pour water down tubing to make sure it is clear.
Next you may need to pull the back panel inside freezer to excess evaporator coils. Turn off or unplug refrigerator while doing this and pour hot water onto ice build up under coils. Once that is clear and water is draining fine into pan under refrigerator, reassemble and your problem should be solved for a few more years again.
Jan 30, 2011 | Refrigerators
WATER AT SHELFS
If the water only forms during the defrost cycle, chances are that the defrost circuit is working as designed. That leaves the pan under the freezer coil in the freezer compartment and the drain tube from it to the pan at the bottom of the fridge. Check for and clear any obstruction in the drain tube. You'll probably have to empty the freezer and remove any ice making equipment in order to get to this area - which is behind the back panel.
You should unplug the fridge before attempting this. Be careful not to damage or pinch off any wire's insulation or refrigerant lines and coil during the dis-assembly and subsequent reassembly.
It may be that some growths have begun in the drain tube. After clearing the tube, could add about a 1/2 ounce of bleach into 3 or 4 ounces of water, and pour the mixture directly down the tube to kill anything that might be growing in it. If you decide to remove and empty the pan under the fridge - just remember there bleach in it. Spilling it will ruin clothes, etc.
I hope this helps! Good luck.
May 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
We have a leak inside of the refrigerator. Water
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 20, 2010 | Refrigerators
Water draining into bottom of freezer and freezing.
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Jan 08, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
There is water accumulating at the bottom of my refrigerator. How do i clear the drain or remove an obstruction?
You can try a flexible plastic tube strong enough to
go through the drain of your refrigerator. Better still
if you can buy, a 1/4 inch diameter flexible spiral
rod for manual declogging equipment. You can buy
it at the hardware stores.
Sep 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Water dripping inside refrigerator
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 07, 2009 | Refrigerators
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
