Question about Car Audio & Video
Becker Mexico 7942 radio I need to change the language to English
My radio is setup in German, & I need to change it to English. There seems to be no mention in the manual
  • Extended84 Dec 07, 2008
    Can somebody give me an advice how to do change the language form German to English at a Becker radio ???
  • 2072 Answers
SOURCE: Xerox Phaser 8560 - Changing Menu from German to English Language
To select the default language on the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Control Panel Setup], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Language], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required language, and then press the [OK] button.
  5. Press the [Back] button, located to the left of the 'Up' and 'Down' buttons, three times to return to the Main Menu.
To select the default language using CentreWare Internet Services (CWIS):
  1. Open an Internet web browser on the workstation.
  2. Enter the IP Address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on [Properties]. The Properties window will be displayed
  4. Click on the [General] folder on the left, and then select [Printer Defaults].
  5. Under the User Preferences section, select the language from the Set Control Panel Language pull-down.
  6. Click on the [Save Changes] button.
  7. Click on the [X] in the upper, right corner to close
If you are talking about the driver menu you have to delete and reload the driver with the english
Posted on Jul 22, 2008
fcsr
  • 43 Answers
SOURCE: car radio
On the face of the stereo is a * button. Push this button then use the numbers on the face of the stereo to go directly to that station. Example, my favorite classical station is 90.7. Push the * then 907. This station will appear in display. Then push and hold for about 5 seconds the preset button you would like this station to be. The stereo will momentarily blink to a different station then come back. Station set.
Posted on Nov 17, 2008
JMMARRERO59
  • 77 Answers
SOURCE: Change the language settings on Grand Cherokee
LOOK AT YOU OVERHEAD CONSOLE. PRESS THE BUTTON THAT SAYS"MENU" UNTIL YOU SEE
"LANGUAGE" LOOK FOR ENGLISH THE PRESS REST BUTTON
Posted on Jan 02, 2009
  • 5 Answers
SOURCE: Need to change language from german to english.
If you are talking about one of the Casio QT6xxx's then you need to.
I . All peripheral devices and terminals of this cluster should be turned off.
2. Connect all of the peripheral devices (such as printer, display etc.) to terminal.
*In case of wire inline:
3. Connect all terminals by inline.
*In case of wireless inline: QT 6000 or QT6600 models
3. Connect Wireless LAN card.
Operation:
4. Turn on all peripheral devices of a terminal.
5. Turn on this terminal while pressing and holding the initialize switch and then release.
6. Next the screen will say push the INIT (initialize) switch to start IPL.
After releasing the key
The IPL will take a few minutes to copy over.
When it is done, Pick the Language you need. enter"20000" (U.S.)," l0000" (other area:English)," 40000"
(other area:German)," 50000" (other area: French)," 60000" (other area: Spanish) and
press the <OK> key.
I will be making a video of this procedure this week, so visit us @ www.casiohelp.com to view it.
Posted on Jul 26, 2009
lonewolf1996
  • 142 Answers
SOURCE: language change
You can change the language that displays in the screens and menus of your device. To change the display language, perform the following steps: 1. Press the Left Softkey to select Start. 2. Select Settings and then Regional Settings. 3. In the Language field, use the Navigation key to select your language. 4. To save the setting, press the Left Softkey to select Done. You must turn your device off and on again for the change to take effect.
Posted on Sep 02, 2009
My goodmans tv LD3270D has changed language when I was trying to change the audio for my tv, it is now in german, and my sky volume is now in german too, I need to get it back to english.
language preferences are usually very early in the set up screens, if you can't toggle it back to English using google translate to help, look for a reset to defaults, default language is usually English, but then you will have to set all your other preferences again: https://translate.google.co.uk/
Jan 01, 2016 | Goodmans Televison & Video
Becker Mexico Pro code
BE7932, 55000688
code is 42511
ukradiocode@mail.com
Dec 15, 2012 | Becker Mexico 7942
Change language from german to english on p3015
Hit the Menu button.
Arrow down to the 6th menu option which is Configure device. Hit OK.
Arrow down to the 3rd Option which is System Setup. Hit OK.
Arrow down to the last option. Hit OK and you can change the language to English. Hit OK.
May 15, 2012 | HP P3015 Laser Printer
Change language to English
This might be a problem.. Windows controls the actual display language (thats the dialog boxes, the windows and all the screen messages you see).
If you have a german copy of windows it might be just german. That means you might NOT be able to change the display language to english.
IF you have what's called windows MUI you might be able to change the display language.
Ask the guy or company you bought it from if they have windows CD's. You're likely going to need them. See if by any remote chance you DO have Windows XP MUI (stands for multi user interface)
It's unlikely you do, but at least ask.
There are options to change the language but it's usually not for the display it's for spelling or how dates and the like appear.
Dec 26, 2008 | ASUS Eee 4G Notebook
Change my system setup to english language
upon bootup, look at options to write to BIOS. Typically, can be any key from F1 to F12. You have a small window in which to stroke the key in which to access BIOS. Once within BIOS, you may change your language to English. Also, once in BIOS, change your settings to depict read format in this order:
CDROM, HHD
Should you have a floppy, enable that as well and place that prior to the CDROM.
Good luck.
Oct 15, 2008 | Computers & Internet
How do i change the language?
I have Brother DCP-130C all in one Printer.
When I installed the software I chose English as the language, but when i am scanning & when i go into printing preferences it seems to be in German. I un-installed & re-installed but still not in English.
Any ideas how I can change the language to english please?
Mar 31, 2008 | Brother DCP 130C All-In-One InkJet Printer
Language problem
I would go to menu and setup. Setup is most likely near the top but even if it isn't, keep going into the various folders until you can scroll through languages. Each language will be written in it's invidividual language (Chinese, Japanese, English are all obvious). Your instruction manual might show you the order of the lineup of the setup screen. This way you won't have to be able to read German to find English.
Oct 01, 2007 | Kodak EasyShare Z650 Digital Camera
Car Audio & Video Logo
299 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
