Question about LG Dishwashers
LG dish washer not draining - LG Dishwashers
    Problem Solver:
  • 3 Answers
Normal 0 Thanks to other info gathered from this site and a few quality hours with the washer, I solved this problem for myself.
I experienced the same problem. Did the same things. OE error Drain pump would not drain. Sounded like it was grinding a bit. Just not draining. Checked the strainer. Nothing. I found this link to the service repair manual which has easy to follow instructions on how to disassemble the washer and get to the pump. Removing the door and the pumps is really not that hard.
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Don't be scared. I'm a novice and it was easy. Wear gloves. Lots of sharp edges. All you really need is a screwdriver and pliers to remove hose clamps.
Anyway, I got the the top cover off, removed the front door panel section and could easily access the drain pump. I first pulled off all the hoses. All clear. Disconnected the pumps (easy once I figured out the clip the pump unit slides into). Note there are 2 pumps - a circulation pump and drain pump (larger one). All clear. Reassembled. Still nothing.
Ran a few loads of wash manually draining after each cycle (to keep the wife happy with clean laundry). Yes, you can do laundry while waiting on the part to be delivered. Just get a bucket and drain the washer after each cycle - easier if you pull off the main drain hose and drain it that way versus the little emergency drain slow (slow!).
Became convinced it must be the drain pump so I ordered a new one for $50 here. repairclinic.com
Installed new pump and reassembled machine in about 20 minutes. Worked great. NOW HERE IS SOME ADVICE THAT MIGHT SAVE YOU THE $50 for a PUMP:
After replacing the pump, I was banging on the old one to see why the heck it stopped working. During the process, I figured out how to actually pull the pump apart. There is a rubber washer around the housing below the blade - pull on it hard enough and the pump slides apart. When it did - holy cow! It was filled with grimy sandy muck. I cleaned it all out, but did not feel like testing it to see if worked. So I likely have a spare should the new one ever go out.
Hope this helps.
Good luck.
Posted on Mar 10, 2009
My lg dish washer leaves the dishes dirty and the soap is still in washer
check water hook up and its hooked up to hot water line or washer is not draining if water still there spray arms may be plugged up
need more info model # help
Dec 04, 2016 | LG Dishwashers
White powder remains on the dishes after washing
Sound like over detergent or washer is not graining properly
adds to bad rince cycling of same water it washed with
Check drain if installed right may be back draining
Jul 20, 2015 | LG Dishwashers
How do i drain my washer out
remove outlet hose hold end below water level empty into basen
Apr 19, 2015 | LG Washing Machines
How to install drain to maytag in cabnet dish washer
ON MOST DISH WASHERS DRAIN IS HOOKED INTO SINK DRAIN.
May 01, 2011 | Plumbing
LG DISH WASHER LE CODE 4th.TIME
Have your service tech remove the door cover and check the wiring harness completely. Especially where it flexes at the bottom. LG had a problem on some of these models with the insulation degrading on the wirw. Replace the wiring harness and the motor again.
Oct 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
DISHES COME OUT WITH DIRT ON THEM
Your incoming water temp should be about 140 degrees. If not boost your water heater temp.
Check the dishwasher drain line. It should be tied up under the bottom of the sink to prevent sink water from backing down the drain into the DW.
Feb 27, 2009 | LG Dishwashers
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
884 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
