Question about HP DeskJet 970cse InkJet Printer
Urgent printing! Light flashing to indicate colour cartridge is low but only want to print in b/white - can u fix it please
  • seahorse7 Nov 02, 2008
    Thank you however I do not have a new colour cartridge and I am trying to print in b/white and still no result.
I own a Deskjet 970 Cse and has been working consistently. However, for some strange reason when I tried to print something, the printer is silent and will not respond. Any suggestions?
Posted on Nov 03, 2008
    Scholar:
  • 89 Answers
Replace color cartridge so the printer doesn't consider it an error. You can print grayscale only in your print settings.
Posted on Nov 02, 2008
  • dcomputerman Nov 03, 2008
    Did you try the grayscale settings? That's your only other option. Print, properties, print grayscale only.
Print is very faded and more brown than black. Cartrige seems ok and indicator does not light for low ink.
i think it means for black print it use colour cartridge
first check ur black one
another if in printer properties there is check on high quality print then it also use colour cartridge for that
Aug 05, 2011 | Office Equipment & Supplies
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
The orange light flashes even though I have changed the colour cartridge, The printer will not print
change the catr insecting unit and the cable together for it to work well. that the problem
May 23, 2009 | HP DeskJet 940c InkJet Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Deskjet printer cartridge problem - won't print
I was having the same problem and just posted it, went back to my printer, put the old cartriage back in and printed, I am taking the refilled cartriage back to walgreens where I had it filled and buying a new/hp cartriage to install.
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
EPSOM STYLUS C62 COLOUR PRINTER PROBLEM! HELP! URGENT!
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Feb 23, 2009 | Epson Stylus C62 InkJet Printer
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Apr 09, 2008 | Lexmark X1240 All-In-One InkJet Printer
Overiding Empty Cartridge error for Dell A10 962
Red flashing light on '8BK' small black cartridge on left hand side.
If this indicates 'low ink' then it is not alerting me on the monitor. I think this is something different because my printing has been interrupted. Aileen
Dec 13, 2007 | Office Equipment & Supplies
HP DeskJet 970cse InkJet Printer Logo
111 people viewed this question
Ben Johnson
