Question about NetGear DG834G Router
Pages hi..i have got a netgear router DG854G ..the problem i have that i got the connection to the net but i cant seem to get pages up ,,can you help me,,
  • Jannette Amandy May 11, 2010
    What exactly do you mean by, "i got the connection to the net but i cant seem to get pages up"?
  • 78 Answers
I had the same problem, now i have none...............
login to....
and find out how............ Check out the ONSPEED banner
and also run a PING TEST. Good Luck
Posted on Nov 17, 2008
I got a Netgear WNR2000, the dealer said it was a great wireless router, but its causing alot of problems.. It seems to shut down after an hour or so if its not in use, and i cant seem to find any...
have u tried to update the firmware in the router.Try this steps open the GUI page by it will ask u a user name and password.User name is :-admin and password is password go to the option maintenence and click on router upgrade and select browse and select the firmware u downloaded and then upload it.This is the link where u can download the file
and then soft reset the router by clicking on the option.back up settings and click on erase and after then made the wireless settings again as it make the router to factory default
May 15, 2011 | NetGear WNR2000 Wireless Router
Why i cant go to
Welcome to Fixya. To access the router page you need a working computer that is connected to the router thru ethernet cable. Open a Browser then type or The Default username is admin and the password is password. Password is case sensitive.
If you can't access the address you can reset the router to its factory state by pressing the reset button at the back using a pen or paper clip. Make sure that the router is on when resetting.
Thanks for using Fixya
Mar 04, 2011 | NetGear WGR614 Wireless Router
Can you help me configure my netgear router? I cant seem to connect to
you can try typing in your browser address bar then press enter this should bring up your routers setting wirelessly but this will only happen if your laptop detects your routers wireless network.
if you can connect your laptop to your router using ethernet cable you can go to the command prompt then type in IPCONFIG then enter this should pull up your ipaddress and the default gateway is your routers Graphical User Interface where you can go and change the settings, your Netgear default gateway should be this is the default gateway that should show in command prompt for netgear routers.
If you are going to use wireless make sure in the router the wireless capability of your router is enabled ^_^
your settings depend on what your Internet service provider requires you for settings
Jun 21, 2010 | NetGear DGND3300 RANGEMAX DUAL BAND...
I have a netgear DGN 3300 wireless-N router. I can't seem to open any web pages. Any advise? Could it be my router settings?
its either router settings or your computers internal security settings
(Anti Virus or Firewall).
I would reset it and start again personally or.........
Try running your internet connection wizard again and that will replace the existing connection to the net when its finished,
If still nothing then reset the adaptor settings
I have an example of a router set up on this link below....
Please rate me thanks
May 07, 2010 | NetGear RangeMax DGN3300 Router
Can only connect 1 computer to 'net on router
rourke, you shouldn't be entering the same settings on both router and desktop. I should only be on the router. It seems like something with DHCP is misconfigured on your router. Make sure it (DHCP) is enabled.
Feb 07, 2009 | NetGear DG834 Router
NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
Jan 25, 2009 | NetGear WGR614 Wireless Router
Wireless connection of netgear wireless router for compaq laptop
When you look on the box that the router came in, you have to look to see what Operating Systems it is compatible with. In many cases, routers will not be compatible with vista. I have a Linksys WRT300N, and it works great with Vista.Hope this helps.
May 04, 2008 | NetGear WGR614 Wireless Router
Netgear wireless router
Try these:
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
Netgear router
Go to, the username is: admin, and the password is: password, OR 1234.  You can follow the setup wizard or manually assign the IP address.  I hope this helps!
Dec 27, 2007 | NetGear WGR614 Wireless Router
Ethernet connection works but can't go wireless
This is your router trying to connect to the modem, ensure that the routers wireless connection is enabled and see if your router when you access it is giving your pc an ip address. Make sure DHCP is enabled for automatic ip address allocation. Run this programme, click Start>run then type ipconfig /flushdns then press enter. This will flush any old addresses given by the modem.
Jan 27, 2007 | NetGear WGR614 Router
NetGear DG834G Router Logo
35 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
