Pluged up battery fully charged but wont come on
SOURCE: My Acer Aspire one notebook screen wont turn on
The link below tells you how to flash the bios and will make you Aspire One work again. I just did it to mine and it took about 1 min to get it to work. Good luck!
http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
SOURCE: Acer aspire one AOA110 wont charge either battery (3 and 6cell)
if your Acer laptop battery or adapter need to be replaced?
SOURCE: Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
SOURCE: Battery Wont Charge
Hi there as per your information there is a chance of battery damaged. So i suggest you use your battery in others laotop for confirmation. If your found the same problem then buy a new battery . Thanks & waiting for your feedback.
SOURCE: Acer aspire 4520 does not power up despite fully
Remove ur battery & clean it with water and put it in to ur laptop then press 5 minutes ur power button
Then ur laptop get started .
Note : Wash ur battery with clean water .
