Question about Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC
Bouncing food bowl
Hello, I dont know why, but many object seems to bounce in the game for no reason. When my pets try to eat, they cant as the food bowl just keep bouncing around each time they touch it! if you know how to fix it, it would be greatly appreciated. sorry for my English mistakes, I do speak French Nancy
  • siorashine Jan 30, 2009
    I have an annoying problem that whenever i try to feed my larger dogz, the food bowl bounces down again. It does it with little dogs but i can get it in a position so they can get it normally, but with bigger dogs like a Golden Retriver or Great Dane it boucnes no matter how hard i try
I realize this is an old post, but if you go to the desktop to feed the pets, you will have no problem!!
Posted on Sep 04, 2012
  • haleyraewill
    haleyraewill Sep 04, 2012
    i realize this is an old post, but if you go to the desktop to feed the pets, you will have no problem!!
Really dont know !
Posted on Feb 15, 2008
Feed your pets on the Desktop Playscene, the food bowl won't bounce.
Posted on Aug 17, 2007
I had the same problem as well. When the food or water goes towards the screen, it bounces. So when my catz and dogz would be at the bottom, I'd move the dish to the top. Then, They'd jump to the top of the screen. Then the dish would hop away becuse they touched it. Then they could jump ont the dish without it bouncing away.
Posted on Feb 24, 2007
What is the main objective of the Mopeio games?
Mope.io is a game of evolution. Bigger eat smaller. Stronger eat weaker. As you can eat more and more food, you grow into bigger and stronger animals. The main objective of mopeio game is you can survive there maximum time in a game. I like this game a lot and I played this game many times. You will also try it.
Jan 30, 2018 | The Video Game Consoles & Games
My dog will eat our food but will not eat his , he is being given wainrights he just wants our food
A dog can go without food for a few days and then will eat when it is hungry. Just stop giving your dog your food and at its normal feeding time give it a bowl of its food. If it does not eat it, take the food away. Then 24 hours later put the bowl of food out for the dog. If it has not eaten it within ten minutes take it away and then 24 hours later put the bowl of food out for the dog again. By now the dog should be happy to eat what it is given.
Mar 04, 2015 | Dogs
Feed puppy
Just put some dog food in a bowl it will eat when it gets hungry also see vet if it won't eat
Jun 18, 2013 | Dogs
Its bouncing when mixing
The head unit is not locked in place. If the lever is in the lock position and it still bounces, the cam lever inside has either snapped off or became loose.
Jan 18, 2011 | KitchenAid Food Mixers
My mixer blades are bouncing against the bottom and sides of the bowl and making a racket. The head of the mixer bounces up and down when I'm mixing very liquid-y mixes. When I made bread, I noticed a...
The BUSH on the spindle is worn out. You will notice that liquid blending might make the liquid to flow out through this . If so it is confirmed. This is usual as the food particles gets caught on and wear off the bush in due time.
the blade unit has to be taken out and the bush must be changed after choosing the right bush for the steel spindle.
You can confirm rotating the spindle and see if this shakes.
Hope this tip confirms the fault.
Aug 21, 2010 | KitchenAid Food Mixers
Doesn't lock tight. bounces
is it the bowl that bounces . if so the beater is bent or not in properly .. ck these ..
Dec 23, 2009 | KitchenAid K45SS Classic Stand Mixer
Dogz 5 feeding problem
it pushing the bowl away i sugest unstaling it then re installing it
Jun 11, 2009 | Video Game Consoles & Games
WON'T HEAT OR CLOSE DOOR PROPERLY. ALL ELSE SEEMS OK
Well firstly if the door wont close properly you shouldnt use this device as if you are in the kitchen whilst it is in use your slowly cooking yourself . If the door is open microwaves can escape and that is Radiation Lethal if you get too much or too close ?.
The reason it is not heating is probably because most of the microwaves are escaping and not bouncing around your oven cooking your food .. but actually bouncing around your home cooking you . My advise to you is get it repaired by a qualified Domestic appliance engineer or bin it and get a new one ..
Regards Vortash
May 12, 2009 | Microwave Ovens
The head to my kitchen aid mixer bounces up when kneading dough
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Apr 05, 2009 | KitchenAid Food Mixers
GENERAL QUESTION
I believe what Tascam means by the 'effect loop' on the 2488Mk2 is simply a send loop within the device which internal effects can be set on (vs. a the 'send loop' which exists when you send a track out the sends, through an external effect device, and then back through one the the 2488 inputs). This effect loop is sent to the stereo bus as well as the bounce sub mix.
To use the internal effects in this way you'd select a track with the 'select' button for the track (or you can do multiple tracks by repeating this process for each track one at a time). Then press the send button and on the top of the screen you'll see the effects loop. Just set your send there to 100 or so and that track will be sent to the internal effect loop and be affected by whatever single effects you have turned on. To print these tracks with effects you can either premaster or create a bounce mix. Just make sure you mute any tracks you don't want in a bounce because a bounce will record anything which is on the stereo bus.
(See page 42 in your manual for Tascam's explanation for using the single effect and page 58 for how to create a bounce submix).
Hope this helps.
bd.
Jan 26, 2009 | Tascam 2488 Portastudio Multitrack...
Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC Logo
503 people viewed this question
Top Ubi Soft Computers & Internet Experts
Rick Ostrowski
k24674
tony wahlman
tony wahlman
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
