Question about Sharp AL 800 Copier
Wrinkled paper Paper comes through OK, but every page has a non-straight vertical wrinkle all the way down the left side of the page. I'm not able top see any jammed paper when I open the front of the machine as if I were putting in new ink.
Bom dia, minha al 800 travou com a queda de energia e aparece h 4 naum sei mais o que fazer alguem pode me ajudarv a desbloquear??obrigada
Posted on Jan 05, 2009
Crease in page when printing cannon image runner 1310
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
May 03, 2013 | Cannon Office Equipment & Supplies
I need help repairing my copier. The pages are wrinkled when they come out. I was making multiple copies when it paper jammed twice in a row. i removed the paper (no pieces left) and now half of my paper...
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Sep 04, 2011 | Office Equipment & Supplies
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
Paper jams and wrinkles every time
If you slide open the area in the back of the printer where you remove the paper jam, you can see two plastic tabs (one on the left and one on the right). They should both be free for the paper to pass. Look around to see if there's any other obstruction.
See if the paper will print without the wrinkle with the back piece open. If it does, there's an obstruction in the paper path such as a paper clip or money. Has happened.
If there is no wrinkle coming from the back when it's open, there there problem is the paper moving through that last piece. Look for an obstruction (First Paragraph of this).
Dec 04, 2008 | HP LaserJet 1200 Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
Sharp AL 800 Copier Logo
132 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
