Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Clips holding hinges on Dacor Epicure ECPS127/130 oven door won't release
I removed my oven door to clean more thoroughly but cannot reinsert. I notice that there are clips on the hinges that have flipped up and seem to be impeding the closing of the door. I suspect these clips are part of the locking mechanism during the self cleaning phase.
Do you know how those clips can be released when the door is out of its frame?
Thanks,
John
  • Dacor Master
  • 19,396 Answers
If you give us the exact model number we should be able to find the schematics and to help you.
Posted on Nov 02, 2008
Dacor
chk the spring and the door hinge. it is probably the hinge-spring that is broke, or slipped out of the hinge. lol.
Apr 27, 2014 | Dacor ECS130 Epicure Electric Single Oven
How to take the door off a decor oven
open door fully left and right hinges have a tab at the top of the hinge close to the range pull both down then close door to approx. 45 degrees till door won't close then pull strait up
Cheers
Dec 10, 2013 | Dacor Epicure ERD36 Dual Fuel (Electric...
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
I have a Dacor ERD36, How do I remove and replace the oven door hinges?
most ovens , you open the door half way, then pull straight up the door will come right off, then you have full view of hinges and bolts
Oct 19, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
How to replace glass on oven door - Dacor Epicure
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Jul 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
