No power checked fuse - Computers & Internet
    Scholar:
  • 172 Answers
Make and model of computer please
Posted on Nov 15, 2008
Why did tail lights fail?
Check the power at the fuse box with a test light.check if the is power at other components.check fuse able link under hood near battery arn,t blown,check switch at brake pedal has power.
Dec 09, 2015 | 1997 Toyota Avalon
I hooked my battery backwards now my 95 GMC won't run no fuel no spark what's can it be
Bad DOG! Break out the checkbook, you may have blown the computer. Need to start there. Not sure if there is reverse polarity diode protection or not. Have it checked. Even at a scrap yard they won't be cheap.
Apr 15, 2014 | Cars & Trucks
98 jeep put new crank sensor ' coil pickup' and coil ' i have no power to the fuse block on finder no fire to plugs and dont here fuel pump
No power to fuse block? This may be the problem. Check all your maxi fuses in the power distribution block. I think all the maxi fuses are hot at all times-check if they are getting power, and fuses are good.
Also in the power distribution center is fuse F15- a 30amp fuse for fuel pump relay, and fuse F6- a 15amp fuse, also for the fuel pump wiring. Check that both are good, and have power-F15 is hot at all times. F6 is hot in run or start.
This is the 4.0L inline 6, right? That is the engine diagram I have. The coil signal is from the ECU. Does the check engine light come on with key on, so you know the ECU is powered?
Dec 09, 2013 | 1998 Jeep Cherokee
No power to windows, radio, dash
I would start by checking if the under dash fuse panel is getting power to all the fuses. A few will be hot at all times (like the brake light fuse, horn fuse), but with key on, all fuses in the fuse panel should have power available to them.
Use a test light, clip the ground clip to a metal bracket, and use the test light probe to touch the fuses at the ends-the little indents on top of fuse is open to the metal strip in the fuse. When the probe touches that strip, the test light should light, meaning power is getting to the fuses. No light? Maybe not grounded good-keep trying until you get a light when touching the fuses through that little **** at top of fuse. When you have a good ground, check all fuses. With key on, all fuses should have power-now you can check the radio fuse and dash fuse.
You can do this also to check for a blown fuse. Even a blown fuse will light the tester on one end of fuse. A good fuse will light tester on both ends of fuse. A blown fuse will only light tester on one end. You can check fuses this way without pulling the fuse out to inspect.
If no power to the fuse panel or to part of the panel, look for a bad fusible link or maxi fuse that distributes power to the fuse panel. There may also be a relay (ignition relay) that the key switch turns on to send power to the fuses that are hot in accessory or run.
Sep 30, 2013 | 2001 Toyota Celica
No power to memrey wire for stero
In the engine fuse compartment... .check fuse #3 (10 amp fuse) to see if you have power to the fuse and coming out of the fuse. If you have no power coming from the fuse, suspect a blown fuse or a broken wire between that fuse box and the radio... if there is no power to that fuse. Check the Maxi fuse number 6, a 30 amp fuse.
Aug 14, 2012 | 1998 Ford Expedition
Vw passat 2004, 1.8T, Radio has no power, I have checked the fuse per the fuse box diagram (20 amp) seems to be ok, but have changed with a new 20 amp fuse, still no power. Is there a secondary fuse in...
first check the aux fuse, then check to see if the clock comes on the radio, if it don't check the radio it should have fuses, check them. check the connector to the radio for power, with the key in the off position you should have 1 12vlt power with the key on you should have 2 12vlt power... if the fuses are good on the radio and you don't have any power to the connector, it could be a relay or ignition switch
Dec 26, 2010 | 2003 Volkswagen Passat
I need a wiring diagram of the power seat for a 97 chevy venture van
CHECK POWER SEAT FUSE.IF FUSE OKAY.CHECK FOR POWER AT SEAT SWITCH IF YES.HOT WIRE POWER SEAT MOTOR STILL DONT WORK. POWER SEAT MOTOR FAULTY.NO POWER TO SWITCH AND FUSE GOOD CHECK FOR A OPEN OR BROKE WIRE FROM THE FUSE BOX TO THE POWER SEAT SWITCH.
Oct 17, 2010 | Chevrolet Venture Cars & Trucks
Need help finding location of power window fuse. Power windows are no longer working, they just quit.
Check fuses underhood. Maxi fuses. Check power window relay. Check fuses in dash. Check the fuses with a test light and check all to make sure they work.
Jul 18, 2009 | 1993 Dodge Dakota
Radio no power 2000 vw beetle.
you may try checking the fuse box and see if the radio fuse is broken, if it is, try to raplace it.
Jul 16, 2009 | 2000 Volkswagen Beetle
Kia optima low beams
First verify that the switch is energizing the relay in both positions by turning the low beams on and then pulling up the relay--does it click? If not, replace the switch. If yes, next check for power on the red wire as it comes out of the column. Switch on, no power--replace the switch. If power, check for power at the head-low fuse in the engine compartment fuse box. No power--find break in wire. If power, check for power on the yellow/red wire as it comes out of the fuse box. No power--repair fuse box. Power--check for power at lamps--same wire. No power--repair yellow/red wire.
Aug 16, 2017 | 2005 Kia Optima
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
