Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer 1015 CD 50 disk - florescent bulbs change
Other numbers on it M4-I TI-MA-81B SCC40315 I need to change the florescent light bulb that goes up and down on the left side and can not figure out how to get it out. The manual says nothing about changing the bulbs. I did change the fuse and all other bulbs that were not working. Do you have instructions on how to change the fluorescent lights? Brad Tussy
  • Anonymous Jul 28, 2015
    You have to remove the color cylinders by removing 1 screw on the top plate, pull it up 1/2 inch, swing the pin out of the motor tray, then tip the fixture and gently slide the color wheel off the fixture. The rest is same as a normal 1/4 turn twist and pull out of the sockets like a normal FL bulb, then replace, and turn 1/4 turn either direction. Then carefully slip color cylinder back. Now the tricky part is line up the whit pin thru the center hole of the color cylinder, place the pin back into the hole in the plate. At the top are 3 plastic wheels, one that has a spring. While pulling the sring wheel out, holding it with 1 finger, and the rest holding the top plate, position the cylinder between the 3 wheels and release the spring loaded one, and while holding the cylinder with one hand use the other to lower the top plate into correct position, then using magnetic tipped screwdriver and position it back and tighten. You may need to jockey the top plate, as it sits over the end of one of the screws that holds the front bubbler tube in place. Be gentle and do NOT touch the bubble tubes to risk damaging them, which then will cost you a great deal to replace them. If you are smart you will also want to replace the FS2 starter located nn the top plate, it comes out by rotating 1/8 turn left and pull out of socket, and reverse to replace in the new one.
    Again be sure to pull the top plate out away from the bubbler tubes. Avoid any contact with them period. There is a black AC wire attached to the top plate so it can only come out a small amount. After changing the bulb you can make sure it works before reassembling the colot tube. Also while there a tiny drop or 2 of lithium grease on the motor gear and shaft would be advised. By tipping the fixture you ca get the color cylinders off and on fairly easily. The hard part is getting it back into the door and you will want to do so by holding the color cylinder tube to prevent it from falling downward as you carefully work the top plate back into place.
    Champion:
  • Wurlitzer Expert
  • 211 Answers
You have to rotate the tube 90 degrees until you hear a click, then it pulls straight out of the sockets at the top and bottom (towards you). In order to grip the tube Wurlitzer put a black plastic cap on the end of the tubes with a bit sticking out for you to get hold of. On models where the colour cylinder is flexable you can actually squeeze it in the middle and grab the tube that way.
Dave.
Posted on Nov 03, 2008
Tip
Money-Saving lighting hints
We are being sold on the idea of florescent lights saving money. Please consider that these bulbs use a much lower amount of power while they are on. Also, be aware that they will "burn" for a longer period (on average) than other illumination types (excluding LED lamps). HOWEVER, it is critical to your pocket book... to be aware of the following :
1. FLORESCENT lamps cost 5 to 10 times the price of an incandescent lamp.
2. ON-OFF cycles reduce the operating life dramatically (for example, a garage door opener that comes on/off several times a day and stays on for only a short period of time will NEVER result in a savings to you). Please use these lamps ONLY in fixtures that are left on for at least several hours each day.
3. The environmental impact of a florescent bulb is dramatically greater than any other lighting device.
4. The longivity claims of the bulb manufacturer are not worth the ink that those claims are made of. If you doubt this, ask the retailer if you can return the failed bulb if you get less than 5,000 hours of life (ha ha).
on Jan 28, 2010 | Computers & Internet
My light problem is i have low beam on right side no low on left side i turn highs on and right side goes out and high on left turns on then when back to lows beams and i pull turn signal to flash high...
If you have separate bulbs for the low and high beams(4 light system), if you pull the turn signal and hold it, all 4 lights will stay on until you release the turn signal. You need to replace the bright bulb on the right side and the low bulb on the left side. If your headlights only have one bulb on each side, then you will have to replace both of them to get everything to work.
Jan 04, 2011 | 2000 Ford Mustang
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
How do you change the brake light on chevrolet caprice 1992
Hello Friend:
To change your brake light on your Car is Done from inside your Trunk, You'll need to open trunk, and on either side there is a cover on the left and right side,That will be removeable.
Just remove the cover with your Hands and it will expose your Wiring to your bulbs and you'll see a metel socket that holds your Light Bulbs, Just turn or Pull that socket out that the Wiring goes to.
Now you can remove your bad bulb and replace it with a new one.
on a Caprice you'll have 2-3 Bulbs in the Lighting assembly just have someone Push down the Brake Pedal. So you can see the Light thats not Working.
This will get your Brake Light Working. Since its only 1- Bulb thats out Eliminates that you have a Bad Brake Light Switch. If both sides are out it could be your brake light swith.
Sir I'm sure this will solve your problem,I thank you for Using FixYa
Please let me know if you solved your Problem by Voting .
Thanks Again From: d_hubbs
Aug 21, 2010 | 1992 Chevrolet Caprice
Minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
Jan 21, 2010 | Minolta DiALTA Di181 Printer
Bmw 328 coupe number plate light only one works but if i change the units to the side that works both work but the right side don't work whats wrong! on the right side i tested the power and it rads 1.1 on...
It sure sounds like there is a break in the circuit to the right hand bulb. See if you can follow the actual wire back to where it goes into the loom. Possibly a push fit plug loose or out.
Oct 06, 2009 | 1999 BMW 318 ti
Change right front turn signal bulb
im not positive but it looks very similar to my moms 2006 honda accord which goes through bulbs like there nothing...on her car in order to change the bulbs you actually have to pop the hood and look down towards the light and you can see the bulb make sure that you take out the blinker bulb and not the low beam bulb also if it is on the right side you may have to remove the battery to see the bulb so look on the left side first and if you can see the bulbs then you will know if you need to take the battery out or not
May 15, 2009 | 2003 Kia Optima
Need part number
I am pretty certain that Beverage Air is owned by Sanyo.
Take a look at their website and see what you find.
But isn't the light holder just a standard florescent or other type of bulb holder?
Jan 29, 2009 | Beverage-Air MT45 Beverage Cooler...
2001 4 dr. chev s-10 The rear left parking light and running light do not work as well as the left license plate light. All bulbs are good and no fuses are blown. The the bulb works when the for the left...
Well, let's take this in seperate parts.
On the licenseplate lights, there is only one wiring lead that goes down there. Comes in on the right side, and jumps over to the left. But they are seperate from the tail lights.
The wiring harness for the tail lights comes down the left side of the truck, and then Y's off at the back to go to either side.
And you have replaced the bulbs or at least swaped the bulbs from side to side (just because a bulb is new, doesn't mean it's good) to test what is good, and what isn't.
Brake/running light bulbs will fit into the socket either way, but they only work if they are in the correct way. (you might want to try turning the bulb around in the socket).
From there, get a 12v circuit tester, and check the power to the sockets. You also want to test the ground to the socket.
This is a 8yr old truck, and there is a chance that 1) the socket is bad 2) there was damage to the wiring that goes to the tail light 3) both of the above.
Once you establish power and ground, then you start looking for unusual things.
Try the tips mentioned, and let me know what you find.
Aug 07, 2008 | Chevrolet S 10 Cars & Trucks
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
902 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
