Question about Celestron CG-5 Mount Telescope
I own a celestron c6 sgt,when im setting it up i have align the 2 index marks on the mount, when i do this the optical tube is not pointing in the exact position as the polar axis,the optical tube is pointing a little more to the right, the declination axis would only need to be turned 3mm to put it right.when index marks lignd i also noticed the counter weight bar which moves around the polar axis does not point directly to the ground. so is this normal or are my index marks (which are glued on) in the wrong position. please help derek
    Genius:
  • 1,027 Answers
The setting circles are out of adjustment.
Posted on Nov 08, 2008
How do I attach telescope tube to eq dovetail mount?
You first have to get 2 tube rings. These must be the right size for your scope.
http://www.optcorp.com/orion-116mm-id-orion-telescope-tube-rings-7372.html
They will have hinges and clamp screws and at least one other hole for attaching to a dovetail rail. Then you need a rail, sized appropriately for your scope. They come in several lengths and 2 geometries, Vixen and Losmandy. Almost certainly you will need the first one.
http://www.optcorp.com/aa-vdup11-vdup11-vixen-style-11inch-dovetail-universal-plate.html
There are some scopes with very fat tubes, like Schmidt-Cassegrains, where the rail attaches directly to the tube fittings.
http://www.optcorp.com/celestron-c6-a-xlt-schmidt-cassegrain-optical-tube-assembly-91010.html
Dec 16, 2015 | Optics
Celestron manuals
www.celestron.com/support
doewnload the manual from the above website.
Jul 27, 2014 | Celestron 91010XLT C6-A C6A 6-In. Schmidt...
Celestron astromaster 114eq see only pitch black
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Dec 27, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
I have a C8-SGT (XLT) Computerized Telescope, just brought it out first time this year. It is not tracking after I slew to an object. I've checked and rechecked the hand control settings. Any...
I assume you mean you have set tracking on by:
Setup key, scroll to Set Tracking, select Sidereal Rate, press Enter
This should get tracking going for celestial objects.
Another possibility, if the mount is not tracking well, is that polar alignment is not very precise. This will immediately show up when doing a 3-star alignment.
Cheers
Nov 07, 2011 | Celestron CG-5 Mount Telescope
Not able to see anything would like how to use cerlestron EQ 114
This is a small reflector style telescope on an equatorial mount. The mount and tripod must be polar aligned in order to be used. Read this:
http://arnholm.org/astro/polar_alignment/index.html
Simply pt the eyepiece with the largest number written on it into the telescope, take the scope outside during the day time and practice focusing on a distant object like a building.
Celestron's manuals are located on this web site-- find your scope and download one for free:
http://www.celestron.com/c3/downloads.php
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Aug 13, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
The alignment peg on my 10" mount sheared off
You can order these from Celestron, contact their customer service department.
http://www.celestron.com/c3/page.php?PageID=37
Mar 04, 2011 | Celestron CG-5 Mount Telescope
I use sky align, it says successful, but will not align with objects,
Did you tain the mount? Is the mount level? Did you center both alignment stars?
Read through this web site:
http://www.nexstarsite.com/index.html
Jan 07, 2010 | Celestron Optics
I have an Celestron advanced Series GT goto mount that does not turn on. I have taken it apart and looked at the circuit boards and power is getting to the switch, but I cannot locate any obvious loose...
Contact either a Celestron Dealer (customer service) or Celestron customer service.
http://www.optcorp.com/ a dealer
http://www.celestronlife.com/groups/all user groups for all Celestron telescopes
http://www.celestron.com/c3/support3/index.php?_m=tickets&_a=submit&group=C3 Celestron Support
Oct 31, 2009 | Celestron Advanced C6-S (60 x 150mm)...
Celestron CG-5 Mount Telescope Logo
122 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
