Question about Toshiba 34HF85 34" TV
Partial picture on screen
When we turned on our TV tonight, we can see a partial picture - in the center of the screen only - a rectangle about 9" x 11". The sound is fine.
2 Suggested Answers
  • 81 Answers
SOURCE: black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Posted on Apr 07, 2007
  • 790 Answers
SOURCE: black rectangle on picture Toshiba CF27H40
maybe your horizontal yoke is defective..
Posted on Feb 25, 2009
0 characters
1 Points
I have a blank black rectangle on my screen. When I hit the menu button I can see the full image in the background but when I exit the menu the rectangle comes back. How do I get rid of it???
Tv still have Close Captioning functions is on.Tries tv remote button like CC turn off all CC1,2,3 to all off.Or goto tv menu goto Close Captioning turn off all CC1,2,3 or Text 1,2,3 to all off.Should stop the rectangle square appearing.
Mar 02, 2011 | JVC AV-27020 TV
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Sharp standard tv turns off by itself. have to
if you know how to solder,resolder the vertical section of your tv especialy the IC.i think it is TDA 3657 it is an IC with 7 to 9 legs
Jul 29, 2009 | Standard (CRT) Televisions
Why did a rectangle box appear on the screen
PIP is on (Picture in Picture) either from your cable box or the TV. Check your remotes for "PIP". If you still have an issue, post a comment and I can help you more
Jul 08, 2009 | Standard (CRT) Televisions
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
Black rectangle on picture Toshiba CF27H40
Feb 25, 2009 | Toshiba CF27H40 27" TV
Black rectangle covers perhaps 90 percent of the screen
Closed caption has to be turned off. link to owner's manual........good success, Meder's Tv Service
Jan 22, 2009 | RCA 27F530T 27" TV
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Nov 03, 2008 | RCA F32650 32" TV
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Blank menu frame overlays TV picture & keeps returning
Activate CC/Text function.If CC1 is on,CC2 may be off position.The key to this scenario is understanding both on and off of text box as well as cc on and off.
Jan 29, 2007 | Akai CF2791 27" TV
Toshiba 34HF85 34" TV Logo
57 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
