Question about Olympus D-555 Zoom Digital Camera
Paper Jam Error when no paper jam
I just opened my new Olypmus D555 Zoom w/Imagelink printer a week ago. Everytime I put the camera on the docking space, it turns on and says cartridge level low (cartridge has never been used!) Then...when I hit print, it says that it is printing and goes through the process, but it shoots the paper out the back of the printer, completely blank, and says that there is a paper jam when there is no paper jam. I've unplugged it, restarted it, checked the cartridge and made sure that it was wound tight with no slack, plugged the printer into its own spot in the wall, and checked all my plugs. How can I fix this? Could it be defective since purchase?
  • Anonymous Nov 10, 2007
    my epson printer says there is a paper jam when ther is no paper in it. what do I do?
  • 114 Answers
Well it could be, but normally the material is always right, therefore it could happen to be really paper jamed that u can´t see.
Posted on Jan 17, 2007
  • maxi Oct 19, 2011
    no creo, si dice que saco el papel saco el papel, no va a ser tan boludo de no cerciorarse bien antes de postear. A mi me pasa lo mismo y cuando escupe la hoja tratando de sacar la "trancada" no la termina de eyectar, la deja 1 pulgada antes y la tengo que sinchar de pesado para que salga. No somos tarados.
    Gracias
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Prints one page double sided, then goes to error light and stops printing
what is the error ?
does it says Paper jam, Open the print cover and remove paper jam..
If this the error repeating then make sure,
1. u r not overfilling the paper tray
2. put the printer on a hard surface (not on a half out surface)
3. from now on be gentle with the paper tray.
4. unplug the printer everytime u r done or atleast overnight.
thanks
Jul 30, 2010 | HP LaserJet 1320 Printer
Keeps telling me to add paper when paper is not needed seems to jam after about third time through the printer dock My printer is a Kodak Easy Share Printer Dock purchased 5 years ago
You may want to try inserting less paper to free up some tray space. Insert about 5 sheets and see if that works. Sometimes too much paper may cause the printer to load incorrectly.
Mar 30, 2010 | Cameras
Paper Jam/Cartridge can't move
Hello Julie how are you? Regarding on your problem try to remove your cartridge then installed it properly. Or try to open the back of you printer and try to see if their is a small piece of paper left during a paper jam incedent you have.
Jun 16, 2009 | HP Officejet 5610v All-In-One InkJet...
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Paper jam
there is a sensor which detects if there is a paper jam in the printer.that sensor is bit moved from its orignal position so it is continuously detecting the paper jam in your case.
Oct 06, 2008 | HP DeskJet F380 All-In-One Printer
HP D155xi - Error Message: Clear Paper Jam (when there is none)
Have an HP office jet d155xl printer and every time I put it on, it takes sometime to warm up then the "scanner failure" pops out on LCD with instructions to put printer off and on again. Same thing happens all over again.
Oct 18, 2007 | HP OfficeJet D155xi All-In-One InkJet...
Olympus D-555 Zoom Digital Camera Logo
101 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
