Question about Maytag PAV2300 Top Load Washer
Maytag Pav2300 top loader balance problem
Every spin cycle the machine jumps and bucks around the laundry room. The machine is 2 years old and never had a problem until now. we first thought that it was a loading issue with to much weight on one side of the drum but even if the load is adjusted the machine will continue to bounce. We have confirmed that the machine is level and the lags are adjusted correctly. the drum was stif to move side to side so we removed the front cover and confirmed that all the balancing springs were in place and intact, we also lifted the drum and cleaned the nylon surface that the drum rides on which made a big differance to the ease the drum moves from side to side now but the machine now jumps more vilently than before. with only a few items in the machine it seems to run not to bad but we wil never keep up to the dirty clothes our kids make at this pace.
  • 4 more comments
  • kbrich27 Nov 18, 2007
    Experiencing the same issue with a PAV3300...is that covered under the SF-26-756 you mentioned?
  • grensan Nov 26, 2007
    Grensan:
    We have the same probs with the model PAV2000. All springs are in place, the loads are balanced and the legs adjusted per the manual.
    Is This model possibly covered under the Service bulletin" you mentioned in the other responses????
  • DrWhat May 13, 2008
    I have exactly the same problem with a PAV3300 and tried fixes like levelling and adjusting the load - but that did not work. I have also noticed that the water level seems lower than usual but I am guessing that is a symptom of the same problem.
  • Todd Sanders Sep 14, 2008
    Same issue here. Tub goes to right rear corner when spinning.
    The only sites I have found that have that kit include a new base also. (160.00) do you know of anywhere I can get the snubber and springs only?
    Thanks
    txwelder
  • Anonymous Oct 19, 2008
    I have had the same problem with my washer years. I have been waiting for this junk to die so I can replace it with anything but a maytag.
  • Anonymous Mar 21, 2014
    machine jumps then switches off
    President:
  • 878 Answers
Bigmur, you need the snubber kit for this washer. There was a service flash out on this model, SF-26-756. The kit includes the snubber and 6 new springs. Condition was, excessive vibration during spin, basket leans to one side. Kit number, 12002357. Check with your retailer...this repair may be covered. Catriver..post back
Posted on Sep 26, 2006
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
Washer walks on spin cycle, leveled unit and put carpet under it and it still walks on spin cycle only. I have had this washer for 7 years, just started recently doing this.
This is a sign of machine out of balance. If it has been OK for some time, until now, I would look at the balance springs (usually three of four holding to bowl to the outside of the machine, and see if one has come off, or is rusted through. Either fix or replace.
Does the machine spin just fine with no washing in?
2TRP
Jan 13, 2010 | Maytag PAV2300 Top Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Will not spin out heavy loads, stated by not balancing 2 mos ago
the transmission is shot after 20 loads a week for 4 and a half years
Oct 03, 2008 | Maytag PAV2300 Top Load Washer
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
444 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
