Question about Lands Phones
Bluetooth HEllo EKSE! I could finally solve the problem with Active sync Thanks! another problem I have is to sen large files via Activesync and cabel to usb. I´m using Spb program to convert dvd:s to wma files they are about 250mb. copy and paste and Drag and drop doesnt work. ? couple of days ago I could easily do it because then when I right clicked on a fil an icon appeared:send to my based unit. So I just pionted at this icon and the file transfer worked perfect. But now it doesn´t appear. What to do? Though the bluetooth connection works to sen large files but it takes a bit more time. /Bengt Mattsson, Stockholm Sweden
  • Lands Phones Master
  • 13,433 Answers
Hey, great to hear you got it to work.
I don't like sending big files over bluetooth, in my personal experience when sending a 2mb video
from my phone to another device the transfer took around 2 minutes. not sure what the speed is there but it can't be too fast..
I would suggest you transfer the file with cable or if your phone has a storage card, use a card reader to transfer the file easyly.
also in your premium here
http://www.fixya.com/support/t1198027-bluetooth
do you still see my solution? I would really appriciate it if you could accept my solution, but make sure you accept the correct solution, sometimes people somehow manage to accept a solution by another expert. So make sure when you accept that your accepting me, (ekse).
also if you need further help just add a comment on this page and Il answer the best I can.
Thanks,
Ekse - Finland neighbor
Posted on Nov 02, 2008
HPiPAQrx5915 wont active sync with pc or laptop by usb or bltooth
What version of ActiveSync are you using? Open ActiveSync on the PC, then open "About ActiveSync" under the "Help" menu - it should be version 4.5. If not, download version 4.5 from Microsoft as a first attempt to fix the problem. If you are using 4.5, try uninstalling/reinstalling again but make sure you do a soft reset (push the pin on the top of the device) before you connect the Ipaq. If this doesn't work let me know and we'll try some other things.
Mar 02, 2009 | HP iPAQ rx5915
Connect to Active Sync using Bluetooth.. Is that possible?
Yes it's possible. In the activesync program, press menu and you should see an option of connect via bluetooth.
Feb 22, 2009 | HTC Touch HD Smartphone
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on iwannatoken@hotmail.co.uk il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
Aug 31, 2008 | T-Mobile MDA
Unable to sync
Usually rebooting the phone will cure this, I presume you have switched the phone off, removed the battery and restarted?
make sure in
File--> connection settings
that usb and the port you have assigned to bluetooth is enabled
(all tick boxes checked)
try deleting the device from active sync
File--> Mobile device --> (select your device)
then go to
File --> Delete mobile device
make sure you have copies of any un-synced data as it may be lost but shouldn't.
If I remember rightly (dont have a touch to hand) also delete the link to the pc in the active sync window on the touch
Menu--> options (select the server name) Menu-->Delete
and re create the profile by plugging in the device.
May 26, 2008 | HTC Touch P3450 Smartphone
PC/PDA "connected" yet PC won't read PDA
try syncing through bluetooth, there could be a problem with the cradle. i have had an issue very similar to yours and had to do a soft reset on my pda. then set up your device to use a blue tooth connection( you may need to buy a bluetooth dongle for your pc).
Feb 06, 2008 | Compaq iPAQ H3850 Pocket PC
Activesync via bluetooth
Click on Ipaq wireless
turn on the blutooth
Click on Manager
at the bottom click on new
and then click active sync via bluetooth and go from there
Jan 02, 2008 | HP iPAQ HX2490 Pocket PC
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
H5555 sync problem
When you attach your ipaq, you should be able to go into My Computer and view the ipaq as a removable storage device, seeing the actual files and folders located on your ipaq. I would attempt to transfer the files via copy and past if Activesync cannot do it. If that solves the problem then its simply that Activesync is encountering some sort of memory overflow, if it still cannot sync then there is a problem with transfer protocol its using.
Sep 07, 2005 | HP iPAQ H5555 Pocket PC
Activesync Problem, Help Pls
Try the following. FIRST & FOREMOST BACKUP YOUR DEVICE TO A "CF CARD" USING THE BUILT IN "CardBackup" UTILITY. This is a much faster option than using ActiveSynch. It ca restore also much faster. Once your files have synched go to options & change the synch options to manual & file conversions to NONE. Remove or switch off the device. Next delete the partnership WITHOUT DELETING THE SYNCH FOLDER !!! Be very careful. Switch on or replace the device on the cradle. Active synch should recognise the device & offer to setup the partnership. Let it do so with "THIS COMPUTER ONLY" option. Once your device is scanned by activesynch one of the options it will offer is of combining the records. Select it & let it synch. I most cases this should solve the problem. Hope this helps.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Lands Phones Logo
78 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
