It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only During drain and spin only All the time
During fill only If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Frigidaire FGX831CS Top Load
Dryer making high pitch squeak, 3 years old. Model FGX831CS1 Frigidaire, Top Load Stacked Washer...
(More)
Dryer making high pitch squeak, 3 years old. Model FGX831CS1 Frigidaire, Top Load Stacked Washer /Dryer. Any ideas?
It's the older Frigidaire stacking top loader model with the wig-wag transmission and is belt-driven...
(More)
It's the older Frigidaire stacking top loader model with the wig-wag transmission and is belt-driven washer. I actually can't find the exact model number, so the one in the here in the post may not be correct. The only model number I can find is FLC271GW1. It makes a lout ticking noise during agitation and the motor seems overloaded when starting to spin. (I know this is the badly designed model where it spins and drains simultaneously) I have recently replaced the belt with the correct type. Any ideas?
my washer fills up but sometimes i have to keep the lid open until it finishes or it starts to...
(More)
my washer fills up but sometimes i have to keep the lid open until it finishes or it starts to agitate
I have a portable washer. The water tube that connects from the washer to the sink has a line shaped...
(More)
I have a portable washer. The water tube that connects from the washer to the sink has a line shaped hole in it. Is it possible to repair it myself, or do i need a new tube?
