Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Some object stuck in my machine
Please can you advise me of how i can slove the problem with a object in the drum of my machine sometime when there is a heavy load and when the machine spin i can heard loud loises it might a a coin or something small not sure
  • huntedman Apr 25, 2009
    Same here. Waiting for the filter is not realy a solution. I need to get into the drum somehow. Any suggestions?
  • Bosch Master
  • 3,463 Answers
Hi.
If the m/c has a filter at the front, check that first, if there is nothing there, then there is not much else you can do at this stage, hopefully the object will find its way into the filter
Posted on Nov 23, 2008
Screw stuck behind drum making it not rotate
You will need to remove the drum and assembly, please check on this link for tips: Drum removal
Jul 07, 2012 | Washing Machines
How to slove error sc 440-02
One of the drum color could be out of the place.
Try to reinstall it again and turn the machine off/on.
If that doesn't work i advise you to call your provider.
Mar 28, 2011 | Ricoh Aficio 2232C Color Copier
MACHINE NOT SPINNING everything else is fine.
It could be either the bearings have collapsed and seized or that an object such as a sock,stone,screw or the like has got down into the drum and jammed it solid.one way to see if it is a small object like a stone or screw which may work is to undo the screw on the pulley,this is normally a torx screw,you will have to undo in an anti-clockwise direction,then gently prise off the pulley but be careful its soft alloy and could break,once off try jiggling the drum it has some end play and this may be enough to release the jammed article.If this does not do it then the drum will have to come apart if it is a split type drum unit.Also try looking around the front by the door seal sometimes if a sock gets stuck it can get jammed around this point and you may see it.
Jan 29, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Metal (wire?) stuck in rotating drum cavity.
Firstly, you can carefully run your hand around the inside of the drum. If you're really lucky the object may poke thru one of the holes enough for you to grab with a pair of pliers. Try turning the drum back and forth to catch the object in the holes. If this doesn't work you can take the sump hose off on the bottom of the outer tub. If all else fails you may have to remove the heater element and more than likely that's where the object is stuck. (Please ensure if you do not but a new element in use some petroleum jelly or washing liquid to get the old element back in, or you may solve one problem but create a leak). Also, when refitting element be sure that it is sat under it's internal bracket or the drum will scrape on it when it turns.
Hope this helps
ps I'm betting evens that it's a bra underwire!
Jul 07, 2010 | Bosch Washing Machines
Foreign object stuck between drum and casing
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi fs 1555 w machine stopped during cycle now drum will not turn
If you cannot turn the machine by hand then it may be an idea to see if the drive belt has snagged around the back end some how take a peep with a torch thru. top.if the belt looks ok it may be that something has got stuck inside the drum.Sometimes socks get stuck between the front of the drum casing and the drum shine a torch around the front by the door seal and see if you can see any objects jutting out if you can be careful and try with a vice grips to pull out if no joy it sounds as if it will have to be a tub out job.Sometimes objects like coins can be fished out thru the back where the heater sits but still a lot of work to get down there.Body of machine has to be split for access.
Good luck
May 04, 2010 | Zanussi F1245W Front Load Washer
Object in the drum
this aint an easy fix.
Sometimes a bra wire gets through the holes and gets stuck.
the only thing you can do is split the drum housing and empty it out.
No hard to to but takes a lot of time and patience.
Sometimes when you are lucky take the pump hose off the drum housing and look in that hole. sometimes it gets stuck there
Mar 04, 2008 | GE WSXH208A Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Drum is stuck
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub. Open washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. keep a rag nearby to dry up spillage of water when removing the rubber host. Good luck !!
Jul 01, 2006 | AEG Lavamat W1050 Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
258 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
