Question about Panasonic TC-20LA2D 20 in. LCD Television
DTV and me
RCN cable company says I have to get a converter box for this tv to get the changes...true?
    Genius:
  • 1,212 Answers
It only has the NTSC tuner. To recieve HD signals, you need to add a converter box.
Most cable and satellite companies by arrangement with the FCC still should work with the analog sets using their converter box without the need for a digital converter.
If all else fails, they do make for a nice computer monitor.
Posted on Dec 18, 2011
What is code for motorola DCT6200 ?
its actually the remote model that matters in this question... well actually both. using RCN cable remotes the code is 002
good luck
Mar 04, 2012 | Arris DCT6200 DTV Receiver
I have a vcr/dvd combo. Can't record on it, was told that was because the cable here is digital. Is there some sort of adapter I can attach to enable my vcr to work again?
The only way to get your cable company's digital cable into the VCR is to provide a separate cable TV converter box for it.
This will be "an additional outlet" as far as the cable company is concerned - which means you'll pay extra for it. The other problem will be that you will have to locate the VCR cable converter away from the one used to send a program to the TV. This is because there is a very good chance that when you aim the remote to change the channel on the TV's cable converter - it will also try to change the VCR cable converter box.
If however, you have HD service on your TV you should not get an HD box for the VCR - unless there are stations that only exist on the HD converter box. This is because your VCR (like all the others in the world) are only capable of recording the old, analog "SD" or standard definition video signals. If you decide to go the route of an HD and an SD converter setup, you may not have a problem with one remote controlling both converters. Ask the installer (or test yourself) before setting it all up and merely assuming it will work as you expect.
If you end up with two identical converter boxes, you're going to need to either separate them so that the remote will not operate both at the same time. If this isn't doable, you might consider placing electrical tape or similar to block the remote signals from reaching the the VCR converter, and use the channel up / down controls on the converter box itself to tune instead. Since the VCR will only record what is sent to it - you'll have to make sure the converter box is not only on, but tuned to the correct channel before each time you want to record something. This brings up the last caveat, you'll need to set your VCR channel to match the output of the converter box (usually ch 3 or ch 4) and record only that channel. You could simply connect the converter audio and video output to the VCR's audio and video input instead. If you do this, make sure the VCR is programmed to record only the audio and video input ("A / V") instead of a channel.
This can sound a little complex - and it is to some people, but with a little work and some time, you'll be able to do this fairly easily. I wish there was an easier way to do this - but not yet with cable companies so far. The satellite providers are ahead on this with "multi-room viewing" service. Something to think about the next time your cable company announces a rate hike.
I hope this was helpful and good luck!
Sep 21, 2011 | Televison & Video
Need remote code for Coby TFTV-1525, Diectv remote controller.
The correct remote code to get your Coby TFTV1525 is 10030. Coby makes tvs for NEC and 10030 is the first code on the NEC list.
Dec 19, 2010 | Coby Televison & Video
Tv tuner will ot detect digital signal in windows media center, vista
All US TV signals are now digital, but most TV tuners are like our old TVs - analog. Are you sure your tuner is a DTV tuner? If not, you will need to replace it or get a DTV converter. A DTV converter will not let your computer pick the channel and time though.
But one footnote. Broadcast digital TV is often not the same a cable digital TV. If you get a cable digital signal it is encrypted to the actual serial number of the receiving box. No broadcast DTV converter can do this. This is how the cable company now controls the number of receivers and one has to pay for EVERY set.
Apr 23, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
Jun 12, 2009 | Protron PLTV-3750 Television
Panasonic TC-20LA2D 20 in. LCD Television Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
