Having problem connecting to internet - Computers & Internet
    Genius:
  • 1,124 Answers
  • Pablo Csaky
    Pablo Csaky Nov 02, 2008
    Lost Internet Connection?
    Often a corrupted Internet connection follows spyware removal. It's as if the spyware gets the last word the next time the computer is rebooted.
    As such, Internet connection problems result from corrupted files or altered Internet settings on your computer. The Internet connection remains present but unusable.
    Unfortunately, when Internet connection problems arise from spyware, technical support from an Internet Service Provider (ISP) may be limited. The better ISPs will try to help, but their responsibility typically ends with providing Internet service.
    If you cannot access the Internet due to spyware, you may be on your own.
    Fixing Internet Connection Problems
    Fortunately, even novices can fix an Internet connection problem caused by spyware - thanks to free software designed for this task.
    These small, easy and effective programs return the Internet settings back to their original state.
    A damaged Internet connection may be due to a corrupted Winsock or TCP/IP stack, exactly what these programs are designed to fix.
    While a basic understanding of Internet protocols helps when repairing an Internet connection problem, this knowledge is often unnecessary.
    Troubleshoot and Fix Internet Connections Problems
    Among the alternatives to access the Internet and fix Internet connection problems include:
    Software Fix
    Mozilla Safe Mode
    Command Line
    Safe Mode with Network Access
    System Restore
    Software Options
    XP TCP/IP Repair, Winsock XP Fix, and LSPFix are three programs designed to fix some Internet connection problems.
    The first two programs work with Windows XP machines, but may also support Microsoft Vista. [Check for updates at the respective Web sites.]
    Though both TCP/IP Repair and Winsock XP Fix are similar, it doesn't hurt to have both, should one fail to work.
How to connect tv to internet for netflix
First, I am assuming that you have the internet connected at your house and I am assuming that you have a wireless access point or a router with Ethernet connections on it. If you do not have these, then you cannot connect to the internet. On most smart TV's they have a "settings" or similarly named menu item, where you can connect to your home wireless system. Select this and then scroll down the menu until you fine something that says internet or wireless or even quick setup. From there you just select wireless, type in your access password and it should work. All this will be explained in the owners manual for your smart TV.
Feb 25, 2016 | Magnavox Televison & Video
Connecting LC-52LE810UN to internet
Connecting to the Internet
To connect your TV to the Internet, you must have a broadband Internet connection.
Use an ETHERNET cable (commercially available) to connect the ETHERNET terminal on the TV to your
broadband router (commercially available).
If you do not have a broadband Internet connection, consult the store where you purchased your TV or ask your
Internet service provider or telephone company.
you need to have a cable connected to the ETHERNET port and then you will get more options. You need to connect it to your router ports. hopefully you have DHCP enabled on the router and then all will program automatically
Feb 01, 2014 | Sharp LC-52LE810UN LCD TV, 52 - widescreen...
Why doesnt my dell latitude d180 not let me get on the internet with a belkin internet card
You didn't give enough information - I have to assume you are using Windows XP.
For a wired connection:
Click "Start"
Click "Control Panel"
Click "Network and Internet Connections"
Click "set up or Change your Internet Connection"
Then use the "Internet Properties" dialog box with the "Connections" tab selected.
Close to the top click the "Setup" box.
this should open up a wizard and from there you will need to enter the information from your ISP.
For a wireless connection you can click on the "Wireless Network Setup Wizard " instead of the "Set up or Change your Internet Connection"
Nov 30, 2017 | Dell Latitude D810 PC Notebook
I am trying to setup a internet connection using yahoo what do i do
Sir,only using yahoo connection it will not provide to setup internet connection.
For internet connection you have to configure all the component which provides you to connect with internet.
These configuration requires LAN card,LAN driver,modem,NIC card,phone and internet service provider to assist the internet to activate the internet.
Apr 12, 2010 | Computers & Internet
I got a Dell desktop computer from a friend who bought it new. It only has a dial up connection so I got it hooked up. Problem that I have is it won't dial out to connect to the internet. Ralphie
Hi dlwbaw
You have to make a new connection.
Go to "Control Panel", find "Network Connections", double click on that, here you choose file (in the menu) and choose "New Connection". Follow the Wizard (choose, new connection to the internet, connection without code/username/password, and normaly people have DSL connections).
Try to connect the pc to the internet now, this should work, if not:
you have to have the setup way from your internet provider, many times they have a manual on the internet. If it is a connection with user name/ code, you have to Edit your friends internet connection (icon on network connections) or make a new connection with this codes.
The codes you get from your internet provider
Some internet providers allow only one computer connected to the internet.
Hope that helps
Have a nice Sunday :O)
Please rate my answer
Sep 06, 2009 | Dell Computers & Internet
I want to connect internet in my pc from my LG GM200
There are two things that you need. 1. A GPRS connection. For this you go to the helpline of AirCel on your phone and have it activated. 2. The CD that must have accompanied the phone. It will have all the drivers that you need. Install them. 3. If the SW that came with the Phone does not create a network connection to connect to the internet, then create an internet connection after connecting the phone thru USB cable. 4. Configure the internet connection and connect.
Jul 28, 2009 | Cell Phones
I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
Internet connection sharing
To share an internet connection, you need to have two network connections, one for the internet connection, and another for your network.
If your DSL has a USB connection, plug it into one of your computers and then then go through the network setup wizard, from there it will walk you through sharing an internet connection.
If all the computers have wireless, you can set up an adhoc network, and share the connection that way.
Honestly, the easiest method would be to go out and buy a router.
Aug 24, 2008 | Microsoft Windows XP Professional With...
Wireless connecting
Regarding your message, all I have to do is click on the internet Explore icon and I am connected to the internet. The wireless service is connected all of the time. My adapter connection is a VIA Rhine II Fast Ethernet Adapter. Hope that this will help you. TKS...
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
