Question about D-Link DIR-450 Router (DIR450)
Cannot connect to router
I can enter the IP address, but it will not connect to the router? Is there anything I can do?
    Genius:
  • 1,124 Answers
Are you typing at your browser the correct IP address?
Is your router connected to your pc via ethernet cable?
If yes, reset your router (insert pin on a small back hole)
Your ip must be http://192.168.0.1
Your default setting (D-Link) are:
user= admin
pass= (blank) no password
You can also see this:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Posted on Nov 02, 2008
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Cannot get wireless internet to work. Set up wireless connection. Icon shows connected, excellent strength. There is another computer icon next to it on the task bar however that shows a red X through it,...
find that ip of the router e.g 192.168.0.1 or something like that
gott to the lan network connection of pc
got tcip option
in ther enter the ip addree 192.168.0.xxx ( anything but ther router address)
subnet mansk 255.255.255.255.0
defualut gateway the routers ip address
primary dns router router ip address
leave the secondary ip blank
Mar 05, 2011 | Computers & Internet
How do i change the router network password? what is the ip adress??
The internal, LAN-IP address is normally set to a default, private number. Linksys routers, for example, use 192.168.1.1 for their internal IP address. D-Link and Netgear routers typically use 192.168.0.1. Some US Robotics routers use 192.168.123.254, and some SMC routers use 192.168.2.1. No matter the brand of router, its default internal IP address should be provided in documentation. Administrators often have the option to change this IP address during router setup. In any case, however, the private LAN-IP address remains fixed once set. It can be viewed from the router's administrative console.
The external, WAN-IP address of the router is set when the router connects to the Internet service provider. This address can also be viewed on the router's administrative console. Alternatively, the WAN-IP address can be found by visiting a Web-based IP address lookup service like http://checkip.dyndns.org/ from any computer on the home LAN.
Another way to identify the public IP addresses of routers, involves executing a ping or traceroute command. From inside a home network, the (DOS) command "ping -r 1" will send a message through the home router that will cause its IP address to be displayed. For example, "ping -r 1 www.yahoo.com" should result in a message like the following displayed on the command prompt:
To change router password Open your Internet browser, type the address of the router into the URL address bar, and open it. The address is typically in the form of 192.168.X.X. This is the local network address. Enter the account name and password to open the router setup utility. Navigate through the setup utility until you find the screen that will let you change the password. You will need to enter the old password to change it. Decide on a new password that has good security to a hacker. The best password is more than 8 characters and uses both lower case and upper case letters and numbers. Some will allow you to use special characters also. Do not make the password anything that can be found in a dictionary or any date of significance. Enter the old password in the change password page of the router. When prompted then enter the new password. You will be asked to enter it twice to confirm that the correct password is entered. Immediately, record the new password in some secure location that you can find if you forget it. Confirm the password change on the router page and log off the router. To check the information and that the router has been setup correctly with the new password, open the router address in the browser again and login with the new information. If you are able to login, you have successfully changed the password. Network: Router Ssl Vpn
Dec 25, 2010 | AudioCodes Computers & Internet
I cannot connect my xboxlive to the router
Hi Friend,
Please follow te steps:
1. Start>Run.type cmd and hit enter
2. type ipconfig/all and hit enter. Note down the IP address of Defaul gateway
3.Type the default gateway in the web browser and hit enter
4.enter the router username and password. Default password is admin with no username.
5. In the router setup page click Applications and Gaming and then click DMZ
6.Select Enable
7.Let the Source IP address be selected as Any IP address
8.In the destination IP address put the IP address of the xbox
Click save settings
Regards
Chiranjeet
Sep 27, 2010 | Linksys WRT120N Router
Entered the wrong ip address
Different manufacturers have differing setup so without the details of the make and model of the router in question it a little hard to help.
Most routers will have the ability for you to reset it to factory default by a button or such on the unit itself - refer to the install documentation that you got with the modem - if you dont have it you may need to aska friend to borrow their PC and access the manufactures support pages for help.
Jul 13, 2009 | Computers & Internet
Defualt gateway problems with belkin54g cannot connect
1. Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
2. Right-click the network connection that you want to configure, and then click Properties.
3. On the General tab (for a local area connection), or the Networking tab (for all other connections), click Internet Protocol (TCP/IP), and then click Properties.
  1. Check the option which says use the following ip address and enter the ip address that you have forced in the belkin router, type the subnet mask 255.255.255.0 and enter the default gate way the ip address of the belkin router (ip address that you use to open Belkins page)
Jun 23, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless connection
JRSavage - The solution you supllied is to assign the IP address to the client. It appears Guest is asking how to log into the Router.
Guest - If the router is a wireless router then you should not have to know it's IP to connect to it, simply looks for it's SSID in WIndows Zero Config wireless util (or the util that came with your wireless adapter)
If you're connected and looking how to log into the router itself you'll want to enter the router's IP address into the address bar of your internet browser.
If you're looking for where you enter the router's IP for NIC configuration, you would enter the Router's IP as the Gateway address.
Feb 23, 2008 | NetGear WGR614 Wireless Router
What should be the IP address of the computers connected to the router?
What should be the IP address of the computers connected to the router?The IP address has to be 192.168.2.xx and the command to find out the IP address is ipconfig (Start -> Run -> "cmd" [enter] -> "ipconfig" [enter]).
Feb 19, 2006 | SMC Barricade 7004 Router
D-Link DIR-450 Router (DIR450) Logo
77 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
