Question about Philips 50P8341 50" Rear Projection Television
Philips model projection
Gets "hot" and shuts its self off. what replacement part do I need? The switch on the front of the tv works fine.
Philips model number 50P8341, Chassis number PTV915, 3911R051F
My tv will do the same thing. it runs for about 45 minutes and shuts down with the power flashing 2 flashes. after a period of time it will reset but it doesnt stay on for long. I am technically trained in electronics so can you help me with the fix. thanks.
Posted on Nov 19, 2008
    Scholar:
  • 120 Answers
Hello dm beatty, First i must ask if you have anything placed on top of the tv? second what i would suggest is for a professional repairman to come and fix it. There are proceedures which you may do it yourself but if you were to mess up it would cost you a new tv. If you would like more assistance to do it yourself place post again and i will be happy to assist.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
Want to change the convergence chip in my philips projection tv model#51pw9363/17f
Has a projector tv model 50p8341 philips that has a pink color to it work fine but the color, has a new board in it going to throw it in the trash is 10 years old if you no anybody that need parts let me know. no one can tell me what is wrong . would you no?
Feb 19, 2013 | Philips Televison & Video
Need a on off switch for tv
Thats the front keyboard which has the o switch and channel and volume buttons etc. You can get the replacement front keyboard for that model from www.tvrepairworld.com
Oct 29, 2012 | Philips 50P8341 50" Rear Projection...
My Philips 60 inch rear projection TV model
Mute the volume and listen at the rear of the unit. You should be able to hear a fan running since these have hot-spots that require some kind of air movment to keep them from overheating. There are protective circuits that will shut down the power supply once a critical temperature is reached.
The second possibility is the power supply itself; these sophisticated units are very energy efficient but have components in them that age and lose their function over time. The main supply should be fairly easy to spot; it will have larger components on it, some cylindrical (capacitors), others block-like.
If the fan is running and it is still shutting down, this supply may need repair or replacement. Look for a part number on the board and inquire at the manufacturer's service center about those possibilities. Have your model & serial numbers of the set available too.
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
I have a Philips Projection TV Model 55PP241761 from label but 55PP241/76 seems to be the number recognized. The chassis # is PTV 918. After a few minutes the audio will shut down. Also the buttons on the...
Hi
Try to replace the sound board and please provide the no that appears on the back of the remote to find the replacement.You can also buy the remote from remotes-central.com or replacement remotes.com.
Mar 15, 2009 | Philips Televison & Video
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
PHILIPS TV 32PT6441/37 SHUT DOWN
it might be due to
  • plug or socket loose where tv is connected.
  • loose connection in switch.
  • some connector loose in power supply
  •  switching transistor in power supply &horizontal section loose or wire open
  • some capacitor loose in oscilltor section in power supply.
  • if you are not tech. person please take help.
  • hope this will help
  • good luck
Oct 16, 2007 | Philips 32PT6441/37 32" TV
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
123 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
