http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
Your Owners manual
Setting the date
The calender display adjusted in this mode appears
when the telephone source is selected
or sources and the feature demo are off.
1 Use MULTI-CONTROL to select
Calendar.
2 Push MULTI-CONTROL left or right to
select the segment of the calendar display
you wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the calendar display:
Day—Month—Year
As you select segments of the calendar display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the date.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
select the segment of the clock display you
wish to set.
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
