Question about Samsung Digimax L730 Digital Camera
No lights shows on the screen when the camera is switched on
L730 camera new one.Problem is Power LED (green)blinks when switch ON the camera
and camera is not able to switch ON.Some times Low Battery comes in screen while
using new battery.
Posted on Nov 19, 2008
My camara is on pc menu all the time
Posted on Nov 02, 2008
Hello, i have a sony cybershot DSC-S650. Expert, my problem is that when i turn my Sony Cybershot on the lens won't look at nothing, it's ust a blackscreen. Can you please help me. Thank you, My...
Make sure that the batteries in the camera are good and turn it on. Is there a light that comes on to let you know that the camera has power and is ready when you press the power button? Does that light come on and what color is it?
If the light ends up green, then you know the batteries are good and the camera is functioning properly and is ready to take a picture. If this is the case, then after you turn it on - look on the back of the camera for the focus zoom in and out buttons. Sometimes they look like a switch that you can rock right or left. Press the switch and look through the lens. Does press the switch or arrows in either direction clear up your view and allow you to see anything? Are you looking through the lens hole or are you using a small screen to view on the back of the camera? If you are looking at a screen on the back of the camera and that screen is black - it means that you dont have the exterior view option turned on in the cameras settings. Sometimes there is a button labeled "view" on the back of the camera to alternate from the exterior view screen on the back of the camera and using the lens hole view at the top. Press that key to make the view screen turn on. If this option is not turned on yet, press the menu key on the camera and use the arrow keys to scroll through the option choices until you find the image preview choices and turn this option on. Then save this choice and close the menu features to see if it comes on.
If you are not getting a power indicator light when you turn the camera on, then replace the batteries. If the light comes on and its something other then green and steady - (like red and flashing) check your camera manual to see what this indicator means. Some cameras show a red light that is flashing when you turn them on to indicate that the memory card is full. Some camera have a red light that is steady to indicate that the battiers are almost out of power and they will show a picture on the digital to indicate how much power you have left before they shut down. Each model camera is different according to the options it came with.
Jul 06, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
LCD Back light
I shows your screen is not properly touching the contacts i think those contacts need to be cleaned with acetone available at maplin or pcb cleaner from philips the assemble again it solves prob coz that contact isnt giving signal to turn light off.
Dec 16, 2009 | Cameras
Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
May 28, 2009 | Kodak EasyShare Z700 Digital Camera
Rear camera to show on screen in reverse? panasonic cq-vd7001u
It sounds like you may not have it wired correctly. When the vehicle is reverse the cam works, but when you shift to any other gear IE: park, drive etc you go to black screen as if no signal. I had basically the same problem on my unit, different unit but...on the back of my unit there was a wire, you probably have the same, that said rear cam 12v dc.I assumed this meant any positive wire would do, but this is NOT the case. That wire must be hooked to the 12v positive reverse light. With my cam I had the wires from the cam hooked up, red to positive reverse light wire, black to ground and obviously video wire to the video in on the unit. but the problem arose with that rear cam 12v dc wire on the back of the unit. It NEEDS to be connected to the same 12v dc wire as the cam itself. This acts as a 'switch' when in reverse, IE: the reverse lights come on sending power to the wires to turn on the cam. When you're not in reverse the camera 'switches off' because the lights are not on, thus no power is being sent to the wires, thus returning the unit to its normal operating screen. This worked for me, hope it helps. Good Luck.
Feb 18, 2009 | Panasonic CQ-VD7001U Car DVD Player
Powershot pro1 viewfinder show blank white
When the LCD screen is open the viewfinder will switch of and when it is closed the viewfinder will switch on. You can switch between the two by pressing Monitor select button to the left of the Eyepiece (Viewfinder). as you look at the back of the camera.
Hope this helps.
Jul 15, 2008 | Canon PowerShot Pro1 Digital Camera
Wv-cp234 panasonic security camera
Sounds like the iris is staying open.
You need to switch the bottom dip switch the other way
The switches are, from top to bottom:
  1. Sync selection switch (LL/INT)
  2. Electronic Light Control/Automatic Light Control selection switch (ELC/ALC)
  3. Detail level selection switch (SOFT/SHARP)
  4. Back light compensation on/off switch (BLC on/off)
  5. Lens selection switch (VIDEO/DC)
Sep 05, 2007 | Panasonic WV-CP244 Fixed Color Camera
Mostly blank screens with moving streaks of light
This is a known problem in the Coolpix 5700 - Nikon will replace the defective CCD at no charge. Go here:
Nov 22, 2006 | Nikon Coolpix 5700 Digital Camera
Samsung Digimax L730 Digital Camera Logo
52 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
