Question about Microsoft Xbox 360 Console
X box 360
Hi when i turn on my console i get an image and then it turns into artifact lines and then no image at all ...then the green rings continue to flash in order around the ring..now i get no image but i hear the sound
Plug in vidio cord to tv!
Posted on Nov 02, 2008
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
No Picture on X-Box
Try flipping the HD switch on the AV adapter near the console (try in both the HD and Standard definition positions).
Aug 13, 2008 | Microsoft Xbox 360 Console
No image on screen
The GPU on your unit is overheating and you are getting artifacts.
The unit needs to be repaired. Try contacting Microsoft and see if they will fix the unit.
Oct 11, 2009 | Microsoft Xbox 360 Console
When i turn the consol on i get three ring i have checked the power cord and it is orange but when i turn the console on it turns green.do u have any idea what is wrong with my system
U need to ship it back to microsoft  and make sure your av lines are in correctly and check the power cord again just don't let it go to four rings then you'll have the ring  of death For More Info go to xbox.com
Aug 12, 2009 | Microsoft Xbox 360 Console
Black screen white dots
This is likely due to Hardware Failure. Your GPU (Graphics Processing Unit) has likely overheated to the extent of artifacting which is when the device begins to have trouble rendering objects and images and crashes constantly. The only viable solution is to send it in if you still have warranty, Otherwise, you'll have to either buy a new Xbox 360 or send it in for repairs from microsoft.
Hope this helps.
-Gadorach
Jul 13, 2009 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Video Game Consoles & Games
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
