Question about Carrier 38CKC042 Air Conditioner
Ruud Furnace Door
Need a front panel door for a Ruud furnace, Model Number UGDA075ACR. Can't find anything on-line, any idea's before I have to purchace a new furnace.
  • noluckchuck Nov 04, 2008
    Hey Thanks hillbuck29, don't know what I was thinking, too much stress I guess. I took your advice mostly, I had some left over sheet metal, so I took some measurements, and made up a panel myself. It turned out a lot better than I expected, and it works perfectly. Its nice to know you have good people out there to help, when you have brain freeze, Thanks again hillbuck29.
    noluckchuck
  • 182 Answers
Measure it and have any sheetmetal shop make ya one up.much cheaper than a new furnace
Posted on Nov 03, 2008
  • Dave Dobransky Nov 04, 2008
    we all have our moments brother.....glad i could help
I have a Ruud Achiever 90 Plus Gas Furnace with Air Conditioner. I have a new Nest Thermostat. What is the correct wiring connections on the Furnace?
A Ruud Achiever gas furnace I believe came in a two stage model for heating. What this means is that you will have a high and a low setting. Your furnace should have two wires that control the heating cycle a W1 and W2. This should correspond with the terminals on the nest thermostat. You may run into issues if you do not have enough thermostat wires to control the furnace. If you are ever in the need for Ruud And Rheem Gas Furnaces we offer a great selection online. Shop Natural Gas Furnace. We also have a chat line which can provide technical support.
Dec 26, 2017 | Ruud Heating & Cooling
I have a ruud gas furnance. No power model number i have, furnance has no power to the 2wire thermostat. Fuse/breaker was replaced with a new one.
Your furnace has a fuse inside on the circuit board. Make sure that is good. Also the circuit has a door switch that breaks power, so when you open the door find the switch press it in then use a muti-meter on the C and W,G, Y terminals to see if you have 24 volts. IF your unit is getting power from the transformer then the break or open circuit is possibly a safety or some other issue and I would then recommend calling in a local professional.
Dec 02, 2015 | Ruud RGPS10EBRGR Zephyr 100K BTU 80%...
Ruud furnace ugda075acr
you would need to get the serial number to find out when it was made. it is at least from the mid to late 80's
Feb 06, 2014 | Weather King 12AJA2401AH Air Conditioner
I have a Ruud UAKA-037JAZ central heat and air unit (Silhouette 11 gas furnace). When I turn the thermostat to heat the heat does not come on. I removed the front panel and there are 2 green lights lit up...
Need furnace model number. It sounds like you're looking for a standing pilot. Your furnace might not have one. Very likely to have a spark ignition type system or hot surface igniter.
Feb 01, 2018 | Ruud UAKA037 Air Conditioner
Rudd model #UGDA-075C-ER furnance shuts off before reaching desired temp setting set it on 73 it will cut off at 66 etc.
Make sure that the air filter is clean and there are no restrictions in the duct system ie. carpet over register, dog lays on vent etc... If that looks OK, check your thermostat to see if it is still calling (sending a signal) to the furnace by inspecting the circuit board. I think this model of furnace will blink rapidly if there is a call for heat. You can confirm what your furnace does by looking at the board when there is a starting of a heat cycle. Keep in mind that you will need to look thru the small viewing window and not remove the door panel that has the door safety switch. The door switch de=energizes the system. The board will also blink a certain number of times if it experiences an error. You can find the diagnostic chart on the wiring diagram pasted on one of the door panels. It may give you a starting point where to look if you have an error code blinking.
Feb 25, 2010 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
Where are the furnace filters in my older furnace?
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
How do you change the air filter on a Ruud silhouette II furnace? Where is it located?
If it is a down flow, it will usually be found in the return air plenum just above the blower. You need to remove the front panels and look inside above the blower. You may need to remove a second door to access the blower section. If it is an upflow, remove the bottom door and look alongside the blower where the return air comes in.
Oct 04, 2009 | Heating & Cooling
Pilot light not coming on
sounds like the unit goes in lockout mode which shutting off the power and putting it back on will reset the computer now the next time it happens dont shut off the power and in the blower compartment on the board there will be a blinking light count how many times and on the door it will explain do not remove the door until you have counted the beeps throgh the little hole
Dec 24, 2008 | Ruud UBHC Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
121 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
