Question about Samsung Cameras
My camera will turn on and go to the samsung screen and then it beeps three times and it turns off
  • balderas301 May 11, 2010
    my camara is on pc menu all the time
  • 3,230 Answers
Well it's just because of lens errors, they are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism. Follow the below steps to do a try to correct it -
1. Remove the batteries from the camera, wait a few minutes. Put a fresh (or new) set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on. (We know that you camera battery's are in good condition but the newest battery help better).
2. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
3. Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots. If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Samsung Service Center. You can follow the below link for tech support -  http://www.samsung.com/uk/info/contactus.html
Thanks for using FixYa!!
Posted on Jul 07, 2010
  • prettyorange Feb 16, 2011
    I tried the above and it still wouldn't work. I also tried popping the battery out once the lens was extended so I could try and clean the barrels. I finally just kee\pt hitting the on button repeatedly while the lens was facing down thinking the dirt might fall out and it finally did start working again. Whether any dirt actually came out of not I don't know. But it worked.
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
My camera will not let me turn it on
Put fresh batteries in and temporarily remove the disk. Make sure the camera powers up. When it does, go to the battery screen and select the correct battery type. Turn off the camera and reinsert the disk, then reformat the disk from the appropriate menu screen.
May 15, 2009 | Samsung Digimax S730 Digital Camera
NV30 froze
Samsung NV30 turns on then beeps then turns off
Oct 29, 2008 | Samsung NV30 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Camera not turning on
my camera just wont turn on period and just used it like half an hour ago
May 31, 2008 | Samsung Digimax D53 Digital Camera
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
Cameras Logo
230 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
