Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Whirlpool Duet Model GEW9200LW1 Dryer
Hello, I have a dryer that is not working. Yesterday we used the dryer without problem and then all of a sudden we started having a problem. You can put the controls on as normal and select the type of cycle and the time for that particular cycle is shown on the control display. When you push the cycle start the time shown changes to "--" and the cycle does not start as normal. When you release the cycle start button it shows the original cycle time for the cycle that was requested. Note - The dryer was working fine yesterday. It is about 4 years old and we have not had problems with it previously. No other symptoms were noticed leading to this problem. I hope you can offer some advise here. I could not find any service manuals online though I was able to find one for the washer. I am somewhat capable of doing repairs myself and am looking for advise as to what the problem is, how to fix it, possibly parts that need to be changes, or whatever advise you can provide. We are hoping for a sunny day to hang out clothes to get us by for now! lol I look forward to your response. Regards, William Laird Edmonton, KY Slightly different problem. When I put the control on normal, it starts, but only for 27 minutes, And the dryness level does not work. Downloaded the repair manual and ran the Diagnostic Tests. All is good. The manual says that when a particular group of LEDs does not light, replace the console (about $160). But the dryer does work in Manual mode, and seems to get hot (the air intake is really hot to touch (duh). But it's not drying very well. My wife had the repairman over and he quoted about $600 to fix it(!!) and said it was either the console or the control board under the top left. I can replace this with a similar LG model for about $650, but should I order the new control panel instead? There are additional diagnostics if "The Unit will not heat", but it does heat, just not enough to dry.
    Genius:
  • 1,124 Answers
You can download the manual here:
service manual
the manual has 11mb and takes a while to appears on the page, so be patient.
Posted on Nov 02, 2008
    Brigadier General:
  • 3,614 Answers
Unplug the unit for a while. reset it. also check the control board it can be faulty
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool Duet Model GEW9200LW1 Dryer
William, start with the simple things first. Make sure the control is not locked by pressing and holding the end of cycle signal for 3 seconds. This will lock and unlock the controls. If that is in order the next step would be the door switch. By pressing in this order: more time, less time, more time, less time you will enter the diag mode and all the lights should light up. Open the door and you should hear a beep and see a code, such as OE,1E,2E etc. If no beep is heard you could have an issue here. You can also check this at the board. You have to remove the top cover by removing the 3 screws in back. Slide the top off toward the back. The board is on the left. With the power disconnected ohm out P1-2 (white wire) and P1-3 (blue wire). With the door closed you should read continuity. Start with this first and post back...Catriver.
Posted on May 07, 2007
My whirlpoolduet dryer is on control lock how do I unlock it model # gew9200lw1
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet however, your whirlpool duet needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer model # GEW9200LW1, when powering up goes directly to touch up, and will not start. thermal fuse ok
Dirty moisture sensing strips? Have you tried cleaning them with windex?e03f8f0.jpg
Number 34 these measure resistance by picking up wetness from the clothes. Dryer sheets can coat these with a non penatrable film which fools the brain into thinking them clothes is dry so it moves towards the cooldown mode and shuts off with wet clothes. Clean them sensor strips real good and party on!
Oct 11, 2010 | Whirlpool Dryers
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Does anyone have any idea when a Whirlpool Duet GEW9200LW1 Dryer was made? Trying to get an idea on a used one that I'm looking to purchase.
The model number tells only the year that model is introduced but the serial number tells the year and the week of production.
Sep 30, 2010 | Whirlpool GEW9200L Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
I have a whirlpool duet model #GEW9200LW1. I need a belt where do I find one in Montgomery, Alabama on a Sunday?
Only an appliance parts store.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 14, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer GEW9200LW1
Hi.
To be sure the element is not faulty, you need to have it tested for continuity, and for an earth fault.
Nov 23, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Washing Machines Logo
201 people viewed this question
Dan Webster
Dan Webster
Sal De
