Question about NetGear WGR614 Wireless Router
Wireless router netgear
I down loaded the router to my laptop, and set the network, i have another labtop in the other room, when i try to get online, with the labtop in the room i can,t get online
Is it possible to download the drivers for Netgear wireless router & Voice adapter WGR613VAL
Posted on Nov 09, 2008
I LOST MY WEP KEY PASSWORD AND NOW MY ROUTER WILL NOT CONNECT TO MY LABTOP
Connect a LAN cable from your laptop to the LAN port on the router then open your browser and enter the Netgear configuration URL -
http://192.168.0.1
Login and go to the wireless settings. you can change the encryption settings and then apply them to the wireless card in your laptop.
If you cannot login to the router because you forgot the password etc. then you can reset the Netgear back to the default settings by pressing the RESET button at the back of the router until the LEDs all flash.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 06, 2010 | NetGear Computers & Internet
Im trying to get wireless connection.Im connected now direct but wanted to know when i go on the site what do i do to troubleshoot and get it working for my labtop? Thanks
Your laptop should have the drivers for th Wireless card. Assuming that you have a wireless card in your laptop. Browse for networks and see if it picks up your wireless network. If it does select it and browse.
If it doesnt then you have to have to go though other steps of troubleshooting.
Please rate if helpful.
Thanks
Apr 09, 2010 | NetGear WGT624 Wireless Router
Not receiving n-type signal from router
Put the laptop next to the router and see what signal you then get. do the following
---- start>control panel>system and maintenance>system>device manager on lefthandside> network adapters click on the +sign>right click on the wifi adapter>properties>now in there there maybe a TAB for advanced which allows you to select the type of signal the adapter is set for - check its not set to G. ----- loss of signal in room, wifi signals can be reduced, if they pass through walls etc - sometimes just a small change in the routers position or aerial alignment can make a big difference ------ download and install - http://www.xirrus.com/library/wifitools.php - you can then monitor on the graph the signal strength and see when it drops off -------- also a change in the wireless channel used on the router can helpp - Use channel 1 or 6 or 11 as they do not overlap - have a look at the other signals being broadcast and what channel they are on - then choose one that is free or also on a very weak signal to minimise interference
Mar 17, 2010 | Broadcom BCM5705 Network Adapter
New laptop can't find network
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 29, 2010 | NetGear RangeMax WPN824 Wireless Router...
I bought a new wireless laptop and want to connect to my netgear router
Is your netgear router already working ?
Is there any other computer able to go online using the same router ?
If there is any other computer online then you don't need to change the settings of the router.
You need to connect to the wireless network.
Click Here for step by step solution
Oct 31, 2009 | NetGear IEEE 802.11b/g - Wireless Router...
Extremely inconsistent connection to router (Net Gear) & Internet
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Netgear router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Netgear router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:Netgear suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router:
Having default wireless settings on the Netgear router may cause conflict with other Netgear routers within your network range.Netgear suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 18, 2009 | Computers & Internet
No conncections
SSID is the network name for your routers network. If you use a linksys router, then the default SSID is Linksys (don't know what it is for others, but would be easy to find out from their website, and the manual for the router.).
SSID's should always be changed, and secruity encryption enabled, when yu set up a wireless network.
Jan 26, 2009 | NetGear WGR614 Wireless Router
Laptop will not connect to wireless network
try to get upgraded antenes for you router. you might have to tweek some of your network card settings to get a better conecsion.
Dec 29, 2008 | NetGear -DSL Web Safe Router/ RP614 -...
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
My 3 different mac laptops with airport can't connect to my wirless
Sounds like you might be accidentally connecting to a neighbour's network instead of your own. You need to go into your wireless settings on each laptop and tell them to connect to your own network.
Jan 16, 2008 | NetGear Super G WGT624SC Router...
NetGear WGR614 Wireless Router Logo
114 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
