FixYa.com
Tags:
D-Link DP 303  Print Server
Where did my printserver go !!! ??? (by 2 users)
posted by ploef on Sep 25, 2006
First - Sorry for my spelling... But what can i say... i'm from denmark :-)
My router was dead, so i got a new one ( Linksys WRT54GL )
Then i re-installed my computer ( Win XP sp2 ) and startet the router up... the IP for the printserver was 192.168.2.102 and after 30 secunds, it got a new IP.. 192.168.2.103 ... and so on...
After 2 minutes i can't find it ...
If i switch the power off for the dp-303 for some secunds the same hapents ...
I think i uses 192.168.2.103 but i'm not sure
I Try to use telnet but it dosen't work...
What shall i do ?
Johnny AKA Ploef
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by SSUTHAM, posted on Aug 03, 2008
EXTENDNET 100X WORKED WELL FOR YEARS ACTIONTECK ROUTE REQUIRED HARD RESET. SINCE THEN UNABLE TO FIND EXTENDNET 100X. IT MAY HAVE BEEN ASSIGNED A FIXED ADDRESS LONG AGO AND NOT REMEMBERED. HOW DO YOIU RESET THE EXTENDNET 100X AND WHAT ADDESS DOES IT RESET TO. SUTTON
Solution #1
posted on Aug 13, 2008
Not Rated (0)
designwallah
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"... your print server is configured with DHCP and not a static IP address (If it is has a static IP address, make sure it is configured for the correct subnet) ..." How can you verify that if you can't get to the printer server URL?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 26, 2006
Not Rated (0)
dugiehowsa
Rank:Wiz Wiz
Rating: 78%, 733 votes
From your initial troubleshooting steps, it sounds like you are having an IP connectivity issue. I will make the assumption that your print server is configured with DHCP and not a static IP address (If it is has a static IP address, make sure it is configured for the correct subnet). If this is the case, you should be able to log on to your broad band router and see what IP address was given out for it in the DHCP Lease section.
Next, try pinging (open a command prompt and type: ping 192.168.2.103) the IP address of the print server. This will confirm that you have proper connectivity to it. Next, make sure you have file and print sharing enabled on your Win XP machine.
This Problem Also Relates To: HP (J4107AABA) (J4107A#ABA) Print Server HP JetDirect 380x Print Server HP Jetdirect 615n Print Server HP JetDirect 680n Print Server HP JetDirect Print Server HP (C7789A) Print Server HP (J4117A#ACC) Print Server
Can you Help with these Print Servers problems?
Print Servers
monitor appear sc990
code sc990 Answer This...
Print Servers
installing network card in...
We have the card. What else do... Answer This...
Print Servers
Sharp AL800 copy machine
When I copy a paper the copy... Answer This...
Print Servers
s450 canon
my printer s450 is not printing... Answer This...
Print Servers
D Link DP 301P+ printer server
I have pinged the address of... Answer This...
Repair Service
Find Print Server Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
