Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Maytag Neptune W/D (Stacked) Drying Irregularly
I have a stacked Maytag Neptune Washer Drier. Over the past several weeks it has been harder and harder to get it to regularly dry clothing and other items. I put them in, set it to automatic, and walk away. Sometimes when it finishes the clothes are dry, other times a bit damp, but often very wet still. The drum is tumbling, but I don't always feel heat, even after the drier has been running for several mintues. I've check the circuit breakers (read someplace that if one fails it will stop heating) but they're fine. I have found that it SEEMS like if I change the "intensity" (regular, medium, delicate, air dry) before I start, then it dries better. Just flipping between settings a couple of times. Any thoughts?
I have a Maytag MUG2000AWW stack drier that heats intermittently. I opened mine up tonight and found that the connector to the gas valve doesn't seem to be making contact. It's on tight, but I can push on that connector while the gas ignition heater's hot and the valve clicks on. I'm off to the store for some terminals tomorrow to improvise a replacement.
Posted on Oct 25, 2006
    President:
  • 878 Answers
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Posted on Sep 25, 2006
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Mar 31, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Feb 02, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Rack for washing & drying machine
There is no rack available to stack this washer and dryer that I am aware of. Certain front load and portable machines can be stacked otherwise it is stacked from the factory.
Jan 11, 2009 | Maytag Performa PAV2200
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Jan 03, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
333 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
