RCA HD52W59 HDTV Projection Television Logo
Posted on Nov 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken protective plexiglass ...
The protective plexiglass front on tv cracked on my daughter/son-n-law's RCA tv. Can it be replaced and is this dangerous to them and their 2 year old if totally removed and continue to use the set?
Anonymous
Level 3:
Genius:
  • Master 1,030 Answers
  • Posted on Nov 03, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1030
Questions
Helped
227532
Points
2244
It is not tecomended that you remove this especally around children. i say this but i personally have one like that but i have no children. the other reson is the screens are easy damaged and they are 250 to replace. You can get another front plexi these are known as the supersheild. or if you can find the right size plexi glass it might find another option. It can be watched but like i said it will just lead to more problems without plexi
Broken front plexiglass rca 52 inch tv
Hello
Contact the nearest authorised service center for RCA at your town.
1helpful
Broken plexiglass screen
If your TV is anything like mine (which I expect it is, since they’re the same brand), all you have to do is use a T-20 screwdriver bit to remove all the screws from the back of the frame around the plexiglass. Once the screws are out, the frame just pops up and the plexiglass is easily removable.
Hello, my son accidentally broke the plexiglass screen on my rca p52960 tv. was wondering how to take unit apart. any help would be appreciated.
If your tv still works, then this will be worth it. Turn the set around and remove the screws that hold the particle backing on. From there, drain the high voltage from the flyback. You'll also need to be very careful not to damage the reflective piece inside. This can be removed also, but be very careful. If you loosen the chassis, you should be able to access the front plexiglass panel. If you have any doubts about doing any of this, please consider taking this in to someone who is certified. Remember: working on tv sets can be VERY dangerous. Especially if you don't know how to drain the 2nd anode. HIGH VOLTAGE!!!
Broken front lense
It depends on whether the lense has a textured finish molded into it; most do.
It it does, you cannot replace it with clear plexiglass.
7helpful
3answers
52" philips flat screen repair
Your best bet is to do a search of your model on ebay, you will likely find one being sold for parts, because usually it's the video boards that go out ij them. So you should find one without a broken screen, but something else on it broken. And if you want to save shipping you can ask the seller to send you just the screen and trash the rest.
2helpful
3answers
2helpful
2answers
Cracked cover D52W19
i have used plexiglass for customers in the past. it has work just fine. rca call this thing supersheild and charges about 200 dollars.
4answers
I need the screen for this tv can you help my son crack it
I think that Thomson is the manufacturer or distributor for RCA parts, keep that it mind when looking for your screen. you might be able to get it at vancebaldwin.com good luck
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
