Question about Harman Kardon FL8350 5-Disc CD Changer
STUCK Door My two year old got CDs jammed behind the tray door.  Now the player neither opens nor closes and I am out of luck.  Can I just unscrew the top and reach in or am I REALLY going to get shocked?
  • 30 Answers
You will not get shocked if you stay away from the power supply, I have worked on several of these,the cd's are pilled up behind the door, remove the screws ,remove the cd's ,and hopefully you did not strip the cd turntable gear. You will know if you the gear is damaged, when you power the unit up after removing the cd's .the turn table assembly will rotate very jerky.or slow ,or It might not move at all..if so let me know i can help you with that..good luck
Posted on Nov 05, 2008
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
The tray will not open. I loaded the cd's into the changer, closed the tray and it sounded like one of the cd's may have slipped. It does not change or play.
my friend u r going 2 have 2 take it apart. you will have 2 unscrew 4 or 6 screws from the side or bottem 2 take off the top a take out the cds yourself. its not hard 2 do.just remember tht a disk changer can b off track. its possible 2 pull it open but dnt do it if u will break the door track
May 09, 2011 | Denon DCM-290 5-Disc CD Changer / Player
The DVD Player won't Open/Close and there is a DVD inside. How do I force it open?
The DVD player jammed, that is why it is not opening.
To get it to open and close, you will have to unplug the player, then unscrew the screws around it. Take off the cover then you will have access to the disc tray. Then you can plug the player and press open, it will attempt to open but stop, then you can try to apply a little force in pushing the disc tray towards the open direction, it will sit properly and open up.
You can as well unscrew the disc tray and remove your disc, then you press the open button and sit the disc tray properly it will open freely and easily after then.
Take care and good luck
Oct 30, 2010 | Mitsubishi DD-4020 DVD Player
I bought the cd changer with my unit & two cds are stuck in it. This happened the third time I used the unit.
this is a mechanism problem. Also, maybe something might have hooked the cd tray and made it stuck.
What you have to do now is to open the player by unscrewing the cover, so that you can gain access to the mechanism inside the player.
After you must have opened the cover, plug the cd changer to light, power it on and use you hand to pull out the tray while you press open button.
Also make observations on the disc tray while you press the open button and check the disc tray and look for what is making it stuck and refuse to open. This is why you need use your hand to support the disc tray by pushing it open from the inside.
I wish you good luck.
Feb 25, 2010 | Bose Wave Radio
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
if under warranty, send for repair.
No warranty, open it yourself and try to open the cd tray/door. remove anything stuck between the tray/door or wriggle the tray/door.
Aug 23, 2008 | Sony Audio Players & Recorders
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Denon CD door jammed
If you are comfortable taking the cover off, you can try removing the cover and then try to help the tray out the same time you are hitting OPEN/Close.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Feb 03, 2008 | Audio Players & Recorders
DVD tray will not remain closed
Try this. With the tray door still open and the power on, press and hold the play button until the door closes. If you hear the disc loading the door will remain closed for play and record.
Have the same problem - works for me!
Dec 15, 2007 | iLO DVDR04
Harman Kardon FL8350 5-Disc CD Changer Logo
256 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
