Question about Samsung SV5000W VHS VCR
Doesn't power ON
It is 1 year old VCR. It is plugged in to 120 AC outlet. The outlet is working. Which component should I replace? Thanks in advance
  • 1 more comment
  • Manny Sangha Sep 26, 2006
    Fuse is fine
  • Manny Sangha Oct 15, 2006
    After testing power testing following are result:
    AL33V is at 15vdc
    AL9V is at 15vdc
    AL15V is at 15vdc
    AL5.8 is at 15vdc
    AL-15.5 is at 15vdc
    AF+ is at 0vdc
    AF- is at 0vdc
    input to AC26- 00001H
    p1 is at 164 vdc
    p2 is at 164vdc
    NB1 is at 0 vdc
    NB2 is at 0 vdc
    Do guys think that AC26-00001H is component in question?
    What else should I check for?
    Why is 15v output on all outputs of AC26-00001H?
    I have attached schematic for it. LOOK AT PAGE 3 AND 4...
    THANK YOU SO MUCH
    Manny
  • Manny Sangha Oct 18, 2006
    Ok.....
    I got a different Samsung broad(mainboard) which fixes the power supply issue. Now when I installed the transport (head assembly) and plug it in...it tries to move the take-in assembly...but it does not move.....
    I have two head assemblies and I tried both. I know they're working day before.
    Any tips.....I just dropped it on of main board and screwed it back in.... all the wires are connected....
    any help will be greatly appreciated...
    Sergeant:
  • 337 Answers
If you have no indication of power at all,(no lights,no display)the fuse is the first component to check but the vcr has be unplug from the wall when you remove the top cover and remove the fuse to check it.Be carefu.
Posted on Sep 25, 2006
My window ac was leaking water and ran down wall and got the plug wet. we have tried drying it out with hairdryer but when we plug it in the reset button keeps switching. do i need a new ac or can i buy a...
It's hard to know which one needs replacing, without testing the outlet first. Unplug the AC unit and outlet in a lamp or some other electrical appliance to see if the outlet works as it should. If does function correctly, then the problem is in the AC unit. But, buying a new power cord will probably not solve the problem. More than likely, one of the circuits or sensors in the control panel got fried, when the water got into the outlet and shorted it out. That's why the reset button n the cord won't reset.
Depending on the age of the uni, you may want to consider having it repaired, rather than replacing it. But, if it's 5 years old or older, I'd opt for replacement.
Now, lets address what caused the problem. Either the drain hole in the drip pan was clogged and or the rear of the AC unit did have enough downward tilt. The general rule of thumb is 1/4" to 1/2" rear downward tilt. This allows the water collected in the drip pan to flow to the rear of the unit and drain away thru the drain hole. Whether you repair or replace the unit, keep this in mind.
I hope I was able to help you and thanks for choosing FixYa.
Aug 22, 2011 | Heating & Cooling
My AV receiver turns off a couple of seconds after I turn it on. I did what the manual said, unplugged the power source and removed all of the speakers but it continues to do the same thing. Anything else...
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate me"AS THUMBS UP" Thanks
  • Jun 20, 2011 | Onkyo TX-SR606 Receiver
    I live in germany (military) what is the power 120-240?
    Good day!! The 120-240 power simply means the supply of your TV can be plug in to 120 Volts AC to 240 Volts AC that will come out to your outlet.For example your outlet is 120 Volts AC you can plug in your TV in there.In short your TV supply is auto-volt.
    I hope this information could help you.Thank you.
    Apr 17, 2011 | Proscan 24LED45QA TV
    Have isolated problem to vhf/uhf connection point. white lines flash in pic. w/a popping sound & if they stay for very long there is a buzzing as in over white or over modulation. problem shows when...
    Problem seems with main tuner in this tv as other AV inputs working fine so please replace main tuner (TU2) to solve this issue.
    There are two tuners mounted on A board TU1 and TU2, please replace TU2 and part number would be written on tuner itself.
    TV is approx 10 years old so I would recommend that do not spend lots of money on it.
    Thanks.
    Feb 27, 2011 | Sony KP-53HS30 53" Rear Projection...
    Yesterday I bought an STP-120 SIMA power inverter
    you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
    Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
    My console will not turn on. It's less than a year old!
    Try resetting the AC adapter.
    1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
    2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
    3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
    Jul 02, 2009 | Nintendo Wii Console
    I get an E9E fault code on my two year old Frigidaire front loading dryer.
    The error code E9E indicates that low voltage is being detected at the control board of the dryer.
    This could be caused by the following factors:
    * The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
    * Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
    * If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
    (NOTE: The dryer should always be unplugged when accessing internal components.)
    A loose wire or burned connection in this area could result in this error code.
    * A failed control board could cause this problem.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Sep 08, 2008 | Frigidaire Dryers
    Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
    Ensure that you are properly recharging the battery.
    1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
    2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
    The plug should be mounted vertically or on a floor outlet (such as a power strip).
    3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
    4. Once the DS Lite is fully charged, the orange charge light will go off.
    Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
    Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
    If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
    Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
    Jul 14, 2008 | Nintendo DS Lite Console
    Samsung SV5000W VHS VCR Logo
    155 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
    Demonic-2011
    Demonic-2011
