I have a Euro Pro EP055 vac and although the motor works, the suction barely works now. I'm pretty handy and took the vac apart, cleaned all the filters and inside, but I can't figure out why I'm not getting the powerful suction I once had. I've had this vac for 11 years and it's been great to me. Any suggestions?
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
SOURCE: Need vacuum bags for euro-pro ep055
http://www.totalvac.com/parts/X10-3005.html?zmam=6843742&zmas=1&zmac=6&zmap=X10-3005
It helps to use Google.
SOURCE: need vacuum cleaner bags for euro pro ep055
Needed bags for this vacuum and FINALLY found them at http://www.totalvac.com/parts/X10-3005.html?zmam=6843742&zmas=1&zmac=6&zmap=X10-3005. Ten bags and two filters for $10.95 plus shipping. Hope this does it for you and anyone needing bags for this vacuum.
Call
EURO-PRO Customer Service at: 800-798-7398
514-842-8691
or Fax to: 514-842-6985
Monday to Friday 8:30 AM - 5:00 PM Eastern Standard Time
Replacement set of 2 Cloth Bags and 2 sets of Filters: $10.95 + $3.95 Shipping & Handling
Replacement set of 10 Paper Bags and 2 sets of Filters: $ 9.95 + $3.95 Shipping & Handling
