Question about EliteGroup 741GX-M Motherboard
Hi, i have a EliteGroup 741GX-M Motherboard and the screen not display. When i start my cpu, i hear this sound : "beep" "beep" "beep". i change the video card but it do the same thing. plz help me TiDoM
  • Anonymous Mar 15, 2014
    elitegroup motherboard power is working give beet without ram then we can install ram then beep after some time
  • 3 Answers
Your computer has memory problems. First check the video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad or they are mismatched .The CAS latency has to be the same and compatible with your M/B. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
Posted on Apr 15, 2007
SOURCE:
Powers up, but no display or keyboard indications.
If nothing shows on the screen and no beeping from the computer that means a bad motherboard or cpu.
if it beeps, how mant and the type of beep, short / long?
Aug 29, 2011 | EliteGroup ECS G31T-M Motherboard - Quad...
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jul 05, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Black screen with constant beep.
Unless you oddly have a key stuck on your keyboard (which will make this sound), the constant beep usually indicates that the CPU fan has failed and the CPU is overheating.. check that it is working ok and if this is not the case, please repost.
Mar 20, 2011 | EliteGroup ECS AMD690GM-M2 Socket AM2...
My 741gx-m2 motherboard produces continuous beeps when i turn on the power, when i remove the ram i get a long 1 second beep followed by a few beeps, i return the ram i get continuous beeps but no display.
reset your cmos see if this helps pull the jumper on the jp3 circuit on the motherboard and short the 2 and 3 pins with the power off and unplugged then put the jumper back to 1 and 2 ! the bios settings are wrong and this will reset the bios to defaults.
Oct 14, 2010 | EliteGroup 741GX-M Motherboard
It goes off automatically
Enter bios and check your CPU temperature, maybe it gets hot (optimal CPU temperature depends on CPU type, but usually it? not normal if it? above 65 *C) and because of that shutdown occurs. If the CPU temperature is high, apply heating paste between CPU and heatsink. Usually if the PSU is defective, the system restarts, shutdown occurs rarely.
If this is the solution for your problem, please rate my post, otherwise give us more details aboutyour problem.
Regards,
Andras
Sep 13, 2010 | EliteGroup 741GX-M Motherboard
What graphic card will fit my 741GX-M V1.0 ELITEGROUP MotherBoard?
Your board takes a AGP type video card 4x/8x . Check out your specs at the Elitegroup site then check out Newegg or tigerdirect for your video card.
Oct 10, 2008 | EliteGroup 741GX-M Motherboard
Power problem i think
If there is no beep, even after removing RAM means you have faulty Motherboard and/or faulty Processor.
Try to reconnect CUP also clean the CPU socket on board and try to test without RAM, if you got long beep (RAM missing) then proceed further i.e. add RAM, HDD, CD/DVD etc step by step.
If didn't get any beep try to test with other motherboard/CPU to find which one is faluty.
Please post your feedback.
Thanks and Good Luck
Iqbal
Aug 18, 2008 | EliteGroup K7VZA Motherboard
Boot up problem: No Bios reading
Try to unplug unnecessary hardware.. just plug in the monitor to video card, power, and the memory.. unplug the IDE cable or SATA and also the USB devices... Observe if your system will boot. sometimes hardware damages prevent your system to boot..
Mar 27, 2008 | EliteGroup 741GX-M Motherboard
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup 741GX-M Motherboard Logo
551 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
