I have the lens end of a cut swann security camera and no connections
SOURCE: micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
SOURCE: i have a bullet cam. it looks as if it has some
Red should be positive. White should be negative. The yellow is your video with the center being the video and the sheild being ground.
SOURCE: sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Testimonial: "Thank You I got it working!!!!! Thanks for the help"
SOURCE: RIPD CAMERA WIRES!!!
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
I think red & white is right & left audio. Yellow is picture & copper should be ground ?
