Question about Nintendo Wii Console
The disc will not eject and the screen was frozen
The screen is frozen and the disc will not eject
    Problem Solver:
  • 18 Answers
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 12, 2009
Disc Stuck In 60G Console
  • Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Game disc dosent pop up and when click on stuff it freezes
  • 1
  • 2
  • 3
  • 4
    Ejecting a Stuck CD in Mac OSX
    • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
    • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
    • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
    • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
    • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
    • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
    • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
    • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
    • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
    • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
    Sep 17, 2010 | Apple iMac G4 Desktop
    I can't eject a dvd from my mac pro desktop
    Try these tips.....usually holding down the touchpad buttton while tapping the eject button during bootup works.
    picexporterror Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
    picexporterror If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
    picexporterror Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
    picexporterror Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
    picexporterror Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
    picexporterror Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
    picexporterror Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
    picexporterror If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
    Oct 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
    Screen freezes playing Blue Ray discs only.
    I answer this question like ten times a day so don't feel bad.
    The blu-ray laser in your PS3 is a three part laser (cd / dvd / blu-ray). They last only 1-3 years with average use. It's a Sony defect.
    Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
    http://rescuetechla.blogspot.com/
    Please feel free to email me any other questions and please don't forget to rate!
    Thanks!
    RescueTechLA
    Feb 24, 2009 | Sony Playstation 3 (PS3) Console
    Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
    My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
    Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
    DVDR 3350H KEEP READING AND WON'T EJECT DISC
    Look under the faceplate where the disc tray ejects and see if there is a small hole. If so, use a straightened paper clip to eject the disc manually by pushing it into the hole about an inch. If that works, then reset the power on the unit and try a nonrecorded type disc to see if the unit works at all.
    Other than that, you'll have to take the unit apart to get your disc out.
    Hope that helps...
    Geno
    Mar 24, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
    Nintendo Wii Console Logo
    196 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
