My 2002 Sony 57" died last month. The cost to fix the B board and install three new tubes will...
(More)
My 2002 Sony 57" died last month. The cost to fix the B board and install three new tubes will be $815.00. I decided to buy new.
I would prefer a 70"+ plasma, but with the $40k price tag. NO thanks. Anywayz.
My living area is rather large. I sit 14 feet back from the TV, so a larger screen size will suit my needs much better than the average 42-50" displays.
I have been looking at the mitsubishi 73" and 82" series C9 (73" only), 737 and 837 series. I have read several complaints on older mits models, but have come across few or none concerning the new model series listed above. I understand the lamp will need to be replaced and I guess I would deal with that problem once a year or so, if it were.
I would like some advice and thoughts regarding these models. I wonder if it would be a decent investment or would I just be entering into trouble land. If the problems are to problematic I guess I would just settle with a 65" but get the panasonic plasma, which I don't think I would have any issues with.
However, due to the living room size, I would like to settle for the larger display IF the newer series mits are quality items.
Thank you for your response.
There is a curveture in the screen in the upper left hand corner. The screen is shadowy with a lot...
(More)
There is a curveture in the screen in the upper left hand corner. The screen is shadowy with a lot of red bleeding through.
keeps shutting off after 30 seconds first the picture will go out, then the sound, and then the unit...
(More)
keeps shutting off after 30 seconds first the picture will go out, then the sound, and then the unit shuts off
We moved our tv, and now it only plays in black & white. When you 1st turn the tv on, it...
(More)
We moved our tv, and now it only plays in black & white. When you 1st turn the tv on, it plays in color, then the left side of the screen turns black and white, and then the entire screen goes black and white. If I record a show, and play it back, it plays in color. Bizzare!!
I have a Mitsubishi WD-52631. When I power it on it has a message that says;TV will shut down in a...
(More)
I have a Mitsubishi WD-52631. When I power it on it has a message that says;TV will shut down in a few seconds, check to see if the airflow is blocked.Then it shuts off. Does this mean the lamp is going bad and I need to take it in to be replaced?
