Question about Ovens
Wolf oven - oven clicks continuously
Hi there,  I have an older model Wolf stove and I love it! When I use the oven though the ignition part tends to make a "tic tic tic" noise for a very long time, even after the oven has reached it's desired temperature. Is that normal? The stove top rings make that "tic tic tic" noise only when igniting initially then the ignition noise stops once the flame has caught.  To make sure that the stove was safe, I had a repair tech. come to my house, he glanced at it, listened to it, and he said that it was normal. That cost me $165 but I have used a lot of stoves over the years and this noise just does not seem right. It clunks off occasionally but it's hard to tell why since it does not appear to by synchronous with the desired temp. Any ideas? Thanks,  Rosaleen
  • 93 Answers
It may be bad electrode or spark module, but most I see is the pilot light went off during operation and spark module tried to reignite the pilot light. in order to fix it, you can try to move (bend the pilot light mounting bracket) to the lower right but make sure the pilot light is approx. 30-45 degree in an angle so tip of the flame is touching the edge of the oven burner tube. also make sure the pilot light has nice blue flame and look like T shape, if you have pilot light flame looked yellow and has U shape then you have to disassemble the pilot light and clean it. Good Luck.
Posted on Mar 02, 2010
    Champion:
  • 254 Answers
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Posted on Nov 15, 2008
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a 36'' Wolf LP oven with 4 burners and a charbroiler in the center, When lighting the charbroiler, the electronic igniter continues clicking up to 5 minutes after the charbroiler lights
Hi.
The igniters are all controlled by a main hub switch located under the cooktop panel.
Replace the sparking igniters module to fix the sticky igniters problem.
Regards.
Ginko.
Mar 03, 2010 | Stoves Ovens
1937 anitque American Stove came with Magic chef cook book and Loraine thermostatic temperature regulator. Having problems getting Oven pilot light to light. Have checked thoroughly for leaks but have...
THE PILOT LIGHT IS IGNIGHTED BY AN ELECTRICAL WIRE THAT IS LOCATED BESIDE THE GAS JETS SO MAKE SURE THE ELECTRICAL IGNITION SYSTEM HAS POWER YOU NEED TO LOCATE THE WIRE AND FOLLOW IT TO FIND THE POWER SORCE THEN CONECT THE POWER SUPLY TO IT , GOOD COOKING.
Nov 22, 2009 | Ovens
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
Oven wont ignite
hi friend,
Yes 1st off it sounds like you got no electric to unit! check it 1st!
if ok then its the spark module located on the back of the stove with all the wires going to it. box about 1"x4" long, either blue,black or white. You can get this at any appliance parts store or go to www.marcone.com with your model #
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Wolf Range Ovens
I HAVE AN OLDER MODEL KENMORE LIMITED EDITION STOVE/OVEN. I DON'T HAVE THE MODEL NUMBER OR OWNERS MANUAL. ANYWAY, I HAVE A PROBLEM, I TRIED TO USE THE OVEN BUT AFTER I SET IT " F5" COMES UP AND IT BEEPS...
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Wolf oven stove top starting problem
This is caused by a bad flame sensor switch. It has a cap tube (copper line) coming from the pilot area to a switch with two wires on the backside.
Hope this helps You
please rate me
Jun 02, 2008 | Ovens
Ovens Logo
495 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
