Question about Canon S520 InkJet Photo Printer
Will not print 4 x 6 prints
My canon s520 refuses to deliver a 4x6 print. i select 4x6 as desired size in both the application i'm using, e.g. Adobe Photoshop cs2, Faststone image viewer, et al. as well as in the preferences in the printer interface, but all i get is a partial image on the lower portion of the paper. i'm sure i am missing something very simple, but i can't seem to find it. many thanks in advance, casey jones
    Novelist:
    Scholar:
  • 167 Answers
Try to find the margin settings of the application that you are printing  with. If margins are setup in a wrong way it will print anywhere it likes.
Aso see the paper size. e.g. A4, A3 etc.
I think you should take a normal a4 paper and print it and see the size of the image and the size of the document that you have created.
Another way to test it is to copy the image(content) only and paste it in some other application like MS Word or something else and try to print it in 4x6.
If it is an image and you can copy it to MS Paint then do it and cut everything else (crop the image accordig to its' size), then print.
Remember to place the paper on the right hand side of the paper tray. (You can do the reverse also if it required.)
Posted on Oct 19, 2007
Not a problem,but I own the canon pixma 310 and I'm not sure how setting it up to print photos is different than regular document printing?
Hi! here is your solution. 1. Select your image. 2. Click your mouse i.e. right click. 3. Select Print. 4. There are many size for example 4x6 5x7. Chose your size you want to print. 5. Select Photo plus Glossy paper. 6. Press print. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
CHEQUE PRINTING CONFIGURATION IN CANON LBP3300
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size or page setup when printing from an application, taking Adobe Reader 6.0 as an example.
Note: The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note: The printer name displayed in this dialog box can be changed in the [Printers and Faxes] folder (the [Printers] folder for Windows 98/Me/2000).
Jan 27, 2011 | Canon LASER SHOT LBP 3300 Printer
I can't get my X5070 printer to print normal size photos. It will print 8X10 but not the 4x6 size photo.
Have you correctly set the page size to 4 X 6?
Are you using the printer in stand-alone mode or are you printing from an application?
Don
Oct 26, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Getting a borderless print
Try this if that helps:
Using iPhoto to create borderless prints To use iPhoto to create borderless prints, please follow all of the steps below:
  1. While logged in as an Administrator, install the latest Canon printer drivers onto your computer (with Mac OS X v10.2 or later as the operating system) and select the appropriate printer as the default.
  2. Launch iPhoto.
  3. From iPhoto, select and open the image you wish to print. (Please refer to the Apple web site for instructions on how to use iPhoto.)
  4. When you are ready to make a print, select from the Menu Bar 'File: Page Setup'.
  5. The Page Setup dialog will appear.
  6. Select the following settings:
    1. Settings: Page Attribute
    2. Format for: <Select the Canon printer you wish to use>
    3. Paper Size: 4x6 (borderless)
    4. Orientation: <Select the matching orientation>
    5. Scale: <Select the appropriate scale>
  7. Select 'OK' and the Page Setup dialog will close.
  8. From iPhoto, from within the Constrain section of the browser window, select from the pull-down menu (i.e., the button directly above the Constrain label) either '4x6' or '4x6 Portrait'. Then, using your mouse cursor, mouse-over the image and when the Cross-Hairs are over the upper left-hand corner of the portion of the image you wish to print, click and drag from the left to the right in a downwardly diagonal motion, releasing the click at the end of the image selection.
  9. Click the 'Crop' button.
  10. From the Menu Bar, select 'File: Print', select your options, then select 'Print'.
  11. This selection, revealed in the iPhoto window will now print as a borderless, 4x6 print.
I hope this information allows you to resolve this issue. If you need further assistance,
please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to
rate this post....thanks!
Apr 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I 560--photo printing on 4"x6" paper
You should be able to do this in print preferences. Open up your general printer box by clicking on Print. Select print preferences then page setup then select page size and a list of sizes will appear just select 4x6 and then paper type, press print and you have done it.
You might be able to get a manual from the Canon website or 'google' for the one you want.
Please remember to rate this solution.
Nov 05, 2008 | Canon BubbleJet i560 InkJet Printer
Printing steps for 4x6 size photo paper
Try this :
1) Within your application click on FILE and PRINT
2) Depending on the application in use, you may see either "Printer" or "Format for". Ensure your printer name is selected here instead of "Any Printer".
3) Click the up/down arrows next to COPIES and PAGES to see all the available setting options:
A) COPIES AND PAGES
Allows you to select how many copies you want and if you want to print all pages, selected pages or a specific page.
B) LAYOUT
Adjust the way the image is displayed on the media for multiple page printing.
C) SCHEDULER
Allows options for when to print a job, such as specific time or to hold the jobs, and the priority of the job to be printed for networked machines.
D) PAPER HANDLING
More page options, such as even or odd pages only, and reverse print order.
E)COLORSYNC
Connects to color options managed by the ColorSync Utility.
F) COVER PAGE
Provides the option of including a cover page or not with your prints.
G) PRINT SETTINGS
Select your MEDIA TYPE and INK. You can also create and save CUSTOM SETTINGS through this area.
H) COLOR MANAGEMENT
Adjusts BRIGHTNESS, CONTRAST, SATURATION, and INK balance. Also gives ability to allow COLORSYNC to control all printer colors.
I) EXTENSION SETTINGS
Provides the option for printing on thick paper and envelopes * This option may not be present with all models.
K) SUMMARY
Details settings chosen in other options.
After making the changes appropriate to your set up and print job, click on PRINT.
Aug 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
Canon S520 InkJet Photo Printer Logo
117 people viewed this question
old marine
old marine
