Question about Radio Shack Cinego D-1000 Multimedia Projector
Unit powers down shortly after start-up
After my unit is on for maybe 3 mins it powers off button in front flashes!!!
    Problem Solver:
  • 11 Answers
I'm not sure that 99% is accurate. On the right side of the unit, if you are looking in the same direction as the unit is projecting, there are two cooling fans. There is one on the left side. If one of those fans is not functioning, the unit can have the same symptom. There can also be other reasons besides the bulb. Best to send it in for repair.
Posted on Jul 20, 2009
I'm having the same issue currently. I was able to get a hold of the Cinego Tech at Radioshack in Texas. He said 99% of the time it is the bulb. I'm currently looking for a replacment.
Posted on Nov 18, 2008
My Acer Chromebook 13 will not power on or charge so can anyone help me with my problem?
try this: remove battery, remove power cable, push and hold down the power button for 1 m (over 60s) do not short time. release the button, insert the power cable. wait 10s then push and hold power button till you see any lite flash release and see if you boot.
some time the static is built and that causes failure to start.
above should clean any static and allow reset of power adapter to function. if yes,. then once you shut down . insert the batter and ;et it charge for 3 mins.. then try to start.
Apr 02, 2015 | Acer CB5 311 T9B0 Chromebook 13 3 inch...
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ·This will reset the TV in order to fix the problem.
    ·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
I have a mitsubishi wd-52631 and the red light is solid I just cleaned out the tv and got a new bulb but when I turn the tv on I get about 2 mins of picture and sound before it turns off. Does any one know...
It is possible either did not get all the dirty areas in front, and rear of set cleaned out or even that the ballast for the unit is this problem since it powers the lamp---lamp will come on and then turn off for a number of reasons.
The set does have a self diagnostic feature which usually is:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
May 02, 2012 | Mitsubishi WD-52631 52" Projection HDTV
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
I have i canon mp210 i got the black and colour ink cartridge refilled, but when i put them back in the black and colour light still stay on. i have held down the stop/start button for more then 5 seconds...
Things to try, unplug printer for a min of 10 mins.
clean the chip on front of cartridge with nail varnish remover very lightly though.
Reinstall the cartridge holding down the button for a min of 5 seconds.
If that dont work maybe one of the cartridges have failed it does happen from time to time.
I have my own remanufacturing business so know the market & technology fairly well.
Nov 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
Red ring
speakers terminal maybe short circuit------connect it properly.
---ventilation holes are blocked----turn it off let it cool down and turn it on.
-------the unit is operating in continuous high power condition---turn it off-----and let it to cool down.-------turn it on.
Aug 04, 2008 | Denon AVR-2307 Receiver
I cant get it to even turn on
remove battery and use it off A/C power adapter, mine only works this way, maybe shorted battery.
Jun 28, 2007 | iRiver PMC-120 Digital Media Player
224 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
